3.1 & 3.2 Extensions DatabaseCss magic 1.0.7 last version
<span class="qte-attr qte_31_32-qte">3.1 &amp; 3.2</span>
Post by martin » Jul 28th, '15, 03:52
This will add some css to make the layout and some hover functions better
This is the last cssmagic to be released the next version is vip only as its a total new ext :whistl:
You must upload this via ftp do not use the ext uploader it will delete the html files unistall your old version and delete data
upload this via ftp and then enable
Your now have some thing like this
these setting work on all themes.
Now to make your theme better go to ext/martin/cssmagic/styles/ and rename the your_style_name_here folder to your style and now you can add what ever you like into that folder.
back up your curent style folder if you used this ext before then upload your style folder.
viewtopic.php?f=82&t=3220
a.forumtitle:hover,
a.topictitle:hover {
    color: #FE0202;
    text-decoration: none;
    padding-left: 20px;
    transition: all .75s linear 0s;
.row-item-link+.list-inner>.forumtitle,
.row-item-link+.list-0inner>.topictitle {
    color: #C00;
.row-item-link+.list-inner>.forumtitle:hover,
.row-item-link+.list-inner>.topictitle:hover {
    color: #12a911;
This topic has 146 replies
