3.1.x Extensions DatabaseCustom Header Logo
<span class="qte-attr qte_31_32-qte">3.1 &amp; 3.2</span>
Referrals: 48
Custom Header Logo
Post by dmzx » Jun 16th, '15, 22:50
Extension Name: Custom Header Logo
Custom Header Logo displays logos and background images in the header. This can changed for all forums and categories independently.
You can also add a logo and background images to all pages like search, memberlist or user control panel - even in subdirectories and pages with queries.
Note:
Path for logo images: images/chl_logos
Path for background: images/chl_backgrounds
Update code
Update code
Update code
Add ACP version
Custom Header Logo v1.0.3
  2. Unzip the downloaded release, and change the name of the folder to `chl`.
  4. Copy the `chl` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/chl/composer.json
  6. Look for `Custom Header Logo` under the Disabled Extensions list, and click its `Enable` link.
This topic has 92 replies
