3.1 & 3.2 Extensions Database 3.1 / 3.2 ⇒ Topic Author
fliper4o
- Status: Offline
- User theme: Dark
Re: Topic Author
Hi sir,
Request! Only text, no box, no colour as 1.0.2. The images I've published are real ones from my live board.
In ACP > Ext > Topic Author
Select colour:
Is empty as I said, I've deleted numbers to see how it will be transparent. v1.0.4 (check the pictures so far)
Select colour:
fliper4o
- Status: Offline
- User theme: Dark
Re: Topic Author
Thank you!
works great
dr.house
- Status: Offline
- User theme: Dark
Re: Topic Author
Italian translation:
O.T. demo:
..hidden advertising...
Nice extension.
Nice extension.
- Status: Offline
- User theme: Dark
Re: Topic Author
That could be a personal site link in each user's profile. Nice idea!
amrco
- Status: Offline
- User theme: Dark
Re: Topic Author
Dear ,
To change the Topic Author to Arabic by ACP, it doesn't allow because you made it very few/limited characters ( only 10 characters ).
The arabic translation needs 12 characters. So, plz allow 2 more characters.
Kaffe
- Status: Offline
- User theme: Dark
Re: Topic Author
Any idea how to modify this so topic authors who are guests don’t get marked as topic authors? If there are more then one guest posting in a thread, they all get marked as authors..
[edit]
Found a solution
in viewtopic_body_avatar_after.html
find:
replace with:
[/edit]
[edit]
Found a solution
find:
<!-- IF postrow.TOPICAUTHOR_ENABLED -->Code: Select all
<!-- IF postrow.TOPICAUTHOR_ENABLED and postrow.POSTER_ID != '1' -->-
Robbie626
- Status: Offline
- User theme: Dark
Re: Topic Author
Simple and amazing extension to inform readers and posters the topic author is during replies.
Hippie459MN
- Donator
- Status: Offline
- User theme: Dark
Re: Topic Author
I was just going through all my extensions and updating a bunch of them and wondering, this one here shows v1.0.4 but the version in CDB at phpbb.com only shows 1.0.2. Assuming this one here is newer then the one over at phpbb?
"I went outside once. The graphics sucked but the game play was ok."
- Status: Offline
- User theme: Dark
Re: Topic Author
No here is the version with ACP control, this one is not on .com.Hippie459MN wrote: Mar 26th, '18, 12:58 I was just going through all my extensions and updating a bunch of them and wondering, this one here shows v1.0.4 but the version in CDB at phpbb.com only shows 1.0.2. Assuming this one here is newer then the one over at phpbb?
Galixte de EzCom
- Status: Offline
- User theme: Dark
FRENCH translation for the Topic Author extension
this is the FRENCH translation for the Topic Author extension, available on phpBB.com and on the EzCom Community.
PR submitted on GitHub:
- The field “Topic Author” for to enter the text is limited to 10 characters so it’s to short for FRENCH language by example,
- The CSS rule text-transform: capitalize; isn’t adapted to FRENCH language because we don’t use an upper-case at the beginning of each word.
amrco
- Status: Offline
- User theme: Dark
Re: Topic Author
amrco wrote: Nov 13th, '17, 08:07 Dear ,
Any help here ?
Is there a way to increase the number of Title characters ?
- Status: Offline
- User theme: Dark
Re: Topic Author
open acp_topicauthor_config.html in topicauthor\adm\styleamrco wrote: Sep 19th, '18, 05:28amrco wrote: Nov 13th, '17, 08:07 Dear ,
Any help here ?
Change this line:
<input name="topicauthor_text_field" type="text" id="topicauthor_text_field" class="inputbox autowidth" value="{TOPICAUTHOR_TEXT_FIELD}" maxlength="10" />
Save and purge cache.
amrco
- Status: Offline
- User theme: Dark
Re: Topic Author
thanks alot sirdmzx wrote: Sep 19th, '18, 05:40
Change this line:
eunaumtenhoid
- Status: Offline
- User theme: Dark
Re: Topic Author
It would be really cool if you could enable/disable the display of this extension in each forum.
sourekv
- New user
- Status: Offline
- User theme: Dark
Re: Topic Author
I would like to ask two questions (similar as on Github)
- Why is there an option to change the description in the admin panel when it’s already set in the language settings/translation?
- Why the ACP setting overrides user language setting?
Vlada
Vlada
Subscribers
