Extensions Database 3.1 / 3.2 ⇒ 3.1 & 3.2 Fixed footer navbar
3.1.x & 3.2.x
19 given 2
Fixed footer navbar
Extension Name: Fixed footer navbar
phpBB extension that will make your navbar (footer) fixed to your board.
[travis]dmzx/Fixed-footer-navbar[/travis]
Code update, validation version.
Demo:
  2. Unzip the downloaded release, and change the name of the folder to `fixedfooternavbar`.
  4. Copy the `fixedfooternavbar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/fixedfooternavbar/composer.json
  6. Look for `Fixed footer navbar` under the Disabled Extensions list, and click its `Enable` link.
19 given 2
Re: Fixed footer navbar
Customise you .css to whatever you like.
Go to ext\dmzx\fixedfooternavbar\styles\all\theme\fixedfooternavbar.css
1 given 2
#wrap {
	margin-top: 5px auto;
and
@media only screen and (max-width: 700px), only screen and (max-device-width: 700px) {
#wrap {
	margin-bottom: 24px;
is good for me small gap at the top of forum and on mobile allows acp link to be see.
* @package Fixed footer navbar
* @author dmzx (www.dmzx-web.net)
* @copyright (c) 2014 by dmzx (www.dmzx-web.net)
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
#nav-footer {
	display: none;
#wrap {
#footer-wrap {
    position: fixed;
    bottom: 0;
    left: 0;
    width: 100%;
    z-index: 10;
#footer-container {
    height: auto px;
    background: -webkit-linear-gradient(#e1ebf2, #FFFFFF, #FFFFFF, #e1ebf2);
        background: -o-linear-gradient(#e1ebf2, #FFFFFF, #FFFFFF, #e1ebf2);
        background: -moz-linear-gradient(#e1ebf2, #FFFFFF, #FFFFFF, #e1ebf2);
        background: linear-gradient(#e1ebf2, #FFFFFF, #FFFFFF, #e1ebf2);
		box-shadow: 0 0 20px #000000;
   border: 1px solid #999999;
   -webkit-border-radius: 6px;
   -o-border-radius: 6px;
   -moz-border-radius: 6px;
   border-radius: 6px;
#footer-container:hover {
    height: auto px;
    background: -webkit-linear-gradient(#F6F4D0, #FFFFFF, #FFFFFF, #F6F4D0);
   background: -o-linear-gradient(#F6F4D0, #FFFFFF, #FFFFFF, #F6F4D0);
   background: -moz-linear-gradient(#F6F4D0, #FFFFFF, #FFFFFF, #F6F4D0);
   background: linear-gradient(#F6F4D0, #FFFFFF, #FFFFFF, #F6F4D0);
   border-radius: 6px;
#footer {
    width: auto px;
    margin: 0 5px 0 5px;
    padding-top: auto px;
    color: #536482;
    position: relative;
#wrap {
Edit added whole css file
Demo yourdomain.com - Index page
cristian
Post by cristian »
Plisss
gives me the white page?
:sad:
1 given 2
What does the ext oe edit ? and purge the boards cache.
cristian
Post by cristian »
Pliss change directori instalations old dzmx new change barfix
How do I change?
I want to change the directory name to another name at dmzx how can I do?
1 given 2
Sorry dont understand what your saying here.
TWEagle
Post by TWEagle »
How have you made the fixed navbar header??
1 given 2
It's an ABD ext on phpbb.com
phpBB • [ABD] Fixed Menu for Prosilver
Just added this ext...
#page-footer .navbar {
	position: fixed;
	bottom: 0;
	left: 0;
	width: 99%;
	background: -webkit-linear-gradient(#B6BFC4, #FFFFFF, #FFFFFF, #B6BFC4);
	background: -o-linear-gradient(#B6BFC4, #FFFFFF, #FFFFFF, #B6BFC4);
	background: -moz-linear-gradient(#B6BFC4, #FFFFFF, #FFFFFF, #B6BFC4);
	background: linear-gradient(#B6BFC4, #FFFFFF, #FFFFFF, #B6BFC4);
	border-radius: 6px 6px 0 0 !important;
body {
	padding-bottom: 35px;
http://mobiletest.me/iphone_5_emulator/ ... iper-e.com
I'll have to look up that [ABD] Fixed Menu for Prosilver - (notice my bottom left and bottom right border radius)
1nv1s1bl3
Post by 1nv1s1bl3 »
Any plans of maxing a "header" version?
Something like this -> https://www.phpbb.com/community/viewtop ... &t=2270616
Extension Description: Add's a fixed menu to prosilver. We take the existing upper menu, excluding the breadcrumbs, and let the menu scroll down the page with the reader.
+1 :smile:
1 given 2
Why not just use the same ext as every one else and that started out on first 3.1 ? yes its marked as ABD but that does not mean it dont work it means the author has not visited i see alot of sites using it.
19 given 2
NavyRet
Post by NavyRet »
Has this been updated to work with 3.2.1? I can't get it to work with that version, so either I did something wrong or it doesn't work with 3.2.1.
