Author: _Vinny_
Extension description: Sidebar Manager for phpBB adds a flexible way to manage sidebars across your forum. It lets administrators create, organize, and position widgets on the left or right side of the board.
Features:
- Dual sidebars: Support for independent left and right sidebar layouts.
- Drag-and-drop ACP: Reorder blocks and move them between columns from the Admin Control Panel.
- Responsive layout: Automatically adapts to desktop screens and hides sidebars on mobile devices.
- Toggleable sidebars: Let users collapse or expand sidebars for a cleaner reading experience. User preference is stored via cookies.
- Custom HTML blocks: Create your own widgets using HTML.
- Built-in system blocks: Includes useful blocks such as Welcome Panel, Forum Statistics, Quick Search, Clock, Calendar, Newest Member, and Recent Topics/Posts.
- Page exclusion rules: Choose which pages should not display sidebars.
- Quick controls: Enable, disable, or delete blocks directly from the admin panel.
Sidebar Manager was built for phpBB forums that need a cleaner way to add useful content without complicating the layout. It gives administrators full control over sidebars, widgets, and visibility, while keeping the forum easy to use and easy to maintain.
Buy me a coffee and support this extension:
Extension version: 1.0.0
Tested on phpBB version: 3.3.16
Download file: sidebar_manager_1.0.0.zip
File size: 49.51 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=16126114#p16126114
