Extension official releasesphpbb [3.2.x] Extensions Database Releases • Change Logo
Extension name: Change Logo
Author: cabot
Extension description: Simple logo changer for phpBB.
With this extension, you will no longer need to modify the files to change the logo, nor make the changes again when you update your board.
Use image hosting or upload the logo to a directory of your board.
Enter its remote URL or the path to the root of the board, then the width and height.
GitHub
Extension version: 1.0.2
Download file: cabot_changelogo_1.0.2.zip
File size: 13.94 KiB
Source: [url]http://www.phpbb.com/community/viewtopic.php?p=15974878#p15974878
