Support Request SupportTopic image
Support Section
medic
Topic image
Post by medic »
Your phpBB Version: 3.3.4
Your knowledge: Beginner
Boardlink: https://amis-med.com/forum
Activate topic image extension
Nothing
Nothing
Hi everyone
After activation of topic image extension in sub forum the load of that forum became slow it take too much to get in is it normal behavior
Check this one https://amis-med.com/forum/viewforum.php?f=15
Thank you
Re: Topic image
Try to set the permission to never for every group.
And check speed then, new version will be out soon.
medic
Re: Topic image
Post by medic »
Tx for reply Where I can find topic image group permission :eyes2:
Re: Topic image
medic wrote: 5 years ago Tx for reply Where I can find topic image group permission :eyes2:
Check ACP permissions tab and then groups, look for Topic Image (tab)
medic
Re: Topic image
Post by medic »
Tx men you are awesome :thumbup:
