3.3.x Extensions Database 3.2 / 3.3Custom index page
Custom index page
Extension Name: Custom index page
With Custom index page you can create a index page before showing your forum, all forum items are hided with this extension
Basic knowledge of HTML, CSS and coding is needed to adjust and make a beautiful index page.
Custom index page v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `customindexpage`.
  4. Copy the `customindexpage` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/customindexpage/composer.json
  6. Look for `Custom index page` under the Disabled Extensions list, and click its `Enable` link.
Re: Custom index page
Taken for explain.
Don't quite understand how or where to change yourdomain.com {{SITENAME}} to my name ?
clight77 wrote: 11 Apr 2021, 16:29 Hi
no {{ SITENAME }} is default in phpbb for your boardname.
out of the box it will take all, just install it and logout to check it.
Hmmm thought that, but on my test site it just says yourdomain.com.
Must be issue with default phpbb file.
I will leave it till Martin can have a look. :)
THKS
Yes sitename is default (clean installation) yourdomain.
If ACP on your main has your domain name it will take the correct name in the extension.
Found it in ACP/General/Board Settings, I never use that setting. DUH...
clight77 wrote: 11 Apr 2021, 16:45 Found it in ACP/General/Board Settings, I never use that setting. DUH...
It must be working out of the box, but if you want to wait np :wink:
your site give me the idea but you already know it :thumbup:
Like it here and will leave it installed.
Yep works good after putting my site name in ACP, I never use that.
Just now looking at changing main background color to my site image :)
clight77 wrote: 11 Apr 2021, 17:01 Yep works good after putting my site name in ACP, I never use that.
look into the css part in acp of the extension.
look for body part and change it to:
     body {
  background: #2D3142;
  font-family: 'Raleway', sans-serif;
  background-image: url(/to_image);
  height: 100%;
  background-repeat: no-repeat;
  background-size: cover;
change /to_image above to your url of the image.
Will do, need a coffee and walk the muttonhead :)
This worked good.
Just have to add it to magic so it works for both light and dark :)
     body {
  color: #F2F2F2;
  background-image: url(/images/cssmagic_images/black_stripe4.png);
  height: 100%;
The result :)
Back it up as i just fixed a small bug/style issue :rolling:
Anders
Post by Anders »
Goodmorning got my site up again some work lol and did see your custom index and did test it and i get this
Forbidden
You don't have permission to access /adm/index.php on this server.
Have inactivate all other extensions and still no good
And have version 3.3.4
SOLVED
it was darn mod security
