3.3.x Extensions Database 3.2 / 3.3Topic Image
Hamidouki-dz
Re: Topic Image
Post by Hamidouki-dz »
Sniper_E wrote: 5 years ago Dm has an extension that will allow you to make those core edits, then you can do phpbb updates and still have your ext core edits.
what is this extension which allows to save all my html codes?
knowing that I have modify some extension with html code.
Re: Topic Image
umi
Re: Topic Image
Post by umi »
Hi dmzx, this ext need an especific size?
On my site, there are images that are showed fine but others not.
Tested with chrome/firefox on phpbb 3.3.3 prosilver/blacksilver
:beers: :beers: :beers:
Status: Online
Re: Topic Image
umi wrote: 5 years ago Hi dmzx, this ext need an especific size?
Can you Pm me test account and url to your board
Re: Topic Image
I think browser firefox can cache it cash memory,you need to clear it
Re: Topic Image
I had that issue in the first test version but it got solved along the way to release version.
umi
Re: Topic Image
Post by umi »
dmzx wrote: 5 years ago
Sure, check pm.
Re: Topic Image
Any plans to add Max image limit and a prune function to this ext? As after 1000 images or so my board slows down my board is heavy user of images as you know...
Status: Online
Re: Topic Image
clight77 wrote: 5 years ago Any plans to add Max image limit and a prune function to this ext? As after 1000 images or so my board slows down my board is heavy user of images as you know...
yes will add some code for it.
Rick8
Re: Topic Image
Post by Rick8 »
Hi, it's really fantastic as I can see, but I have installed on a forum that I have for some test and I obtain this error:
Fatal error: Uncaught Error: Call to a member function getParameter() on null in /homepages/3/d776074155/htdocs/SoundtrackJungleTest/foro/includes/functions.php:2999 Stack trace: #0 [internal function]: msg_handler(2, 'Use of undefine...', '/homepages/3/d7...', 139, Array) #1 /homepages/3/d776074155/htdocs/SoundtrackJungleTest/foro/vendor/symfony/config/Resource/ReflectionClassResource.php(139): ReflectionClass->getDefaultProperties() #2 /homepages/3/d776074155/htdocs/SoundtrackJungleTest/foro/vendor/symfony/config/Resource/ReflectionClassResource.php(117): Symfony\Component\Config\Resource\ReflectionClassResource->generateSignature(Object(ReflectionClass)) #3 /homepages/3/d776074155/htdocs/SoundtrackJungleTest/foro/vendor/symfony/config/Resource/ReflectionClassResource.php(66): Symfony\Component\Config\Resource\ReflectionClassResource->computeHash() #4 [internal function]: Symfony\Component\Config\Resource\ReflectionClassResource->serialize() #5 /homepages/3/d776074155/htdocs/SoundtrackJungleTest/foro/vendor/symfony/conf in /homepages/3/d776074155/htdocs/SoundtrackJungleTest/foro/includes/functions.php on line 2999
Beer
Re: Topic Image
Post by Beer »
Everything works well! :tumbsyes:
1. New images will be added automatically without clicking the Grab images button and and old images removed?
2. How can I add processing of my tag
[pic = FileTitle]sample_image.jpg[/pic]
Status: Online
Re: Topic Image
Rick8
Re: Topic Image
Post by Rick8 »
This extension is fantastic, but I obtain this error after installing:
Parse error: syntax error, unexpected ')', expecting variable (T_VARIABLE) in /homepages/3/d776074155/htdocs/SoundtrackJungleTest/foro/ext/dmzx/topicimage/cron/prune_topicimage.php on line 34
Status: Online
Re: Topic Image
Rick8 wrote: 5 years ago This extension is fantastic, but I obtain this error after installing:
Did fix it download again and upload the files.
Re: Topic Image
Thanks for the cron/prune DM :)
