3.2 & 3.3 Extensions Database 3.2 / 3.3Download limit
Re: Download limit
As Martin said,also me testing from same ip could be an issue also.
Re: Download limit
1 user is still claiming he can't download after near 24 hours, would using a proxy make a difference?
THX.
Also waiting for Sniper_E to reply to see if he was reset.
The guy was reset he said 24 hours but it was not I explained to him about the time zone and board settings, he can download again...
Also he was using a VPN and had switched from the Netherlands to Spain, that could make a difference, right ?
Status: Online
Re: Download limit
clight77 wrote: Dec 22nd, '19, 14:17 1 user is still claiming he can't download after near 24 hours, would using a proxy make a difference?
THX.
Is this solved for you?
Re: Download limit
Yes, sorry, for some reason I thought I had replied to this.
I must have replied in a chat with Martin, it seems as though members using a proxy or VPN will affect this setting, so I just included in the language file a 2 or 3 hour time variable for those who use proxies or VPN.
Thanks.
Re: Download limit
I tested this on on a proxy and if remember right i went past the set time by 30 minutes ie set for 2 hours but could download after 2 hours 30 mins.
Normal isp was perfect on time.
Status: Online
Re: Download limit
martin wrote: Jan 13th, '20, 16:40 I tested this on on a proxy and if remember right i went past the set time by 30 minutes ie set for 2 hours but could download after 2 hours 30 mins.
ok will look into it :thumbup:
Yemmy
Re: Download limit
Post by Yemmy »
Greetings
Please how can I set up my Cron on cpanel... I try coping Cron for my ACP to cpanl but it's didn't work.
Status: Online
Re: Download limit
Yemmy wrote: May 23rd, '20, 16:30 Greetings
You dont have to set cron in cpanel for this extension.
Re: Download limit
Slovenian translation
Status: Online
Re: Download limit
Re: Download limit
I still get leechers that complain it goes way past the set time limit before it resets.
They claim they are not on VPN or Proxy.
I have it set for 12 hours but some leechers say they are at 36 hours and still can't download.
Any ideas?
Cheers
Re: Download limit
Go download on mine until you hit the limit.
Re: Download limit
Cron is running just not clearing the table.
Re: Download limit
Still many members that go well past the set limit before they can download again, and it is not Proxy or VPN.
Re: Download limit
Don't seem to work at all now for nobody. :(
Martin now thinks it is an extension conflict... We are trying to find the one..
