Extensions Database 3.1 / 3.2 ⇒ 3.1.x Username BBCode
3.1.x & 3.2.x
Username BBCode
Extension Name: Username BBCode
Author: Sniper_E
Extension Description: Adds user's username to posting.
username_bbcode_1.0.0.zip
  2. In the `ext` directory of your phpBB board, create a new directory named `sniper` (if it does not already exist).
  3. Copy the `username` folder to `/ext/sniper/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/sniper/username/composer.json
  4. Navigate in the ACP to `Customise -> Manage extensions`
  5. Look for ` Username BBCode` under the Disabled Extensions list, and click its `Enable` link.
1 given 1
Re: Username BBCode
Shall make some changes as it shows on posting page even tho bbcode is set to no also dont work in mchat.
Re: Username BBCode
The bbcode this ext creates in acp / posting is set to no show in posting. That bbcode should not show in posting.There are event templates that create a username bbcode icon that inserts [username] into the textarea.
It works in mchat also but the page has to be refreshed for the name to show. Or someone can join your server after you posted it in mchat and they will see it because their page has to load.
In Posting, the page has to refresh on preview or submit so it works fine there. But if you see some changes to make it work better that I don't see... share!
Hey, it works good in Board Announcements and Contact Admin also.
1 given 1
Re: Username BBCode
Ahh yes i see a refresh is needed if you want to see it :tumbsyes:
Re: Username BBCode
Thanks for looking at it. Hey, maybe a refresh can be added to the onclick= codes in the button for mchat. Maybe?
I did cheat to make it work in mchat and added a line in mchat/styles/all/template/javascript/mchat.js (line 410)
        addMessages: function ($messages) {
            location.reload();
Works great in mchat that way.
But I need a functon in this extension that will read that event,
if data-mchat-action { location.reload(); }
No idea how to do that from within this extension.
1 given 2
Re: Username BBCode
Nice work :thumbup:
