3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Custom Header Logo
Exabot
- Status: Offline
- User theme: Dark
Re: Custom Header Logo
Estonian translation.
Exabot
- Status: Offline
- User theme: Dark
How to display it on mobile?
Edit: solution found.
- Status: Online
- User theme: Dark
Kevicar
- Donator
- Status: Offline
- User theme: Dark
The extension works perfectly, but there is a small problem (W3C validation).
What is the problem for it to be valid?
https://validator.w3.org/nu/?doc=https: ... x-web.net/
Thank you for your help and for this extension
- Status: Offline
- User theme: Dark
Should be
<style> and max-width
example
W3c has changed since this ext was made.
example
@media all and (min-width : 350px) and (max-width : 700px) {
.mchat-rooms-body {
min-width: 100% !important;
Kevicar
- Donator
- Status: Offline
- User theme: Dark
As I understand it, these instructions are obsolete and should be removed.
overall_header_stylesheets_after.html
and
Thank you for your help and thank you for telling me if this is correct.
I have no more errors ...
<style type="text/css">
( 2x )
and
@media only screen and (max-width: 850px), only screen and (max-device-width: 850px)Replace with Replace the preceding lines with the following
@media only screen and (max-width: 850px)I have no more errors ...
Aforce
- Status: Offline
- User theme: Dark
I was wondering if you could advise on the best way to show the Custom Header Logo on the FAQ page, for example?
I can't seem to get it to work
The 'Page Name' is faq and I have set the 'Path To The Page' as help
However, when I look at the full path it shows /app.php/help/faq ? Anything with app.php seems to present an issue.
- Status: Online
- User theme: Dark
use app/help/faqAforce wrote: 6 years ago Hi
Aforce
- Status: Offline
- User theme: Dark
Thanks dmzx, that worked a treat.
Tharius
- Status: Offline
- User theme: Dark
Hi @dmzx
This extension was exactly what I needed. I can edit style sheets manually but I shouldn't have to maintain a GitHub repository to keep track of all the files I've tweaked along the way just to keep a forum configured.
Things were going well once I bypassed the phpbb site and came here directly. I'm sure I'll be looking at a bunch of your add ons, thanks for writing them.
I used one of the page 1 posts and tried to decipher what was required and most of my site is showing my logo. I got cocky and tried to figure out the ACP's format from an example […]/adm/index.php?i=-dmzx-chl-acp-acp_chl_module&sid=c14baaf1d0dbc8edf4b6900b5f26daff&mode=pages
Well, the page is index and the path is adm … but no luck. As you see here I tried a few variants, even hoped that acp would be enough, and would appreciate your insight as to what would work to get the ACP to show the logo.
Note that I have url rewriting enabled.
Tharius
- Status: Offline
- User theme: Dark
Any thoughts on what I have done wrong here?
- Status: Online
- User theme: Dark
No this is not possible for ACP pages.
The extension is active only on 'core.page_header_after' => 'page_header_after',
TrekRed
- Status: Offline
- User theme: Dark
PHPBB 3.3.5 PHP 8.1
An excellent extension, but where there is no logo, an error pops up, and where it is, there is no such error.
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/chl/event/listener.php on line 99: Trying to access array offset on value of type bool
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/chl/event/listener.php on line 100: Trying to access array offset on value of type bool
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4129: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3008)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4129: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3008)-
- Status: Offline
- User theme: Dark
Thats a php error prob 8.1.x
