3.1.x Extensions Database 3.1 / 3.2Set forum width 3.1.x
Extension Name: Set forum width 3.1.x
With this extension you can set forum width in ucp in pixels.
Set forum width v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `setforumwidth`.
  4. Copy the `setforumwidth` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/setforumwidth/composer.json
  6. Look for `Set forum width` under the Disabled Extensions list, and click its `Enable` link.
