3.1 & 3.2 Extensions Database 3.1 / 3.2Santa hats
Santa hats
For other exts you may need to add
{% EVENT dmzx_mchat_before %}
just before the
<div class="forabg">
martin_hats_1_0_0.zip
Unantastbar
Re: Snow and hats in header
Post by Unantastbar »
German Translation Snow and hats in header
snowhatsheader_de.rar
A
Hartenheer
Post by Hartenheer »
I am bad in English sorry.
Where do I
find?
You dont need to edit any thing to get it to work.
if you have another extension installed and want a hat on it then follow the code in the first post.
A
Hartenheer
martin wrote: 23 Dec 2016, 20:07 You dont need to edit any thing to get it to work.
DMZX has done for me.
I have no idea where to look for it
Sorry
Hartenheer wrote: 23 Dec 2016, 20:28
Sorry
Yes I installed the hat snippet and switch extension on your forum.
A
Hartenheer
dmzx wrote: 23 Dec 2016, 21:04
Sorry
In first with google translate :oops:
I try the snow, but do not know where file must adapt
Je hoeft dit ext dmzx de fragmenten versie voor u heeft geïnstalleerd nodig
:lol:
I will PM Hartenheer
Files in first post updated it's now a ext demo here http://www.martins-phpbb.com/testing/3.2.1/ hats and snow.
FlexPlay
Post by FlexPlay »
Hello, would you specify which files should be edited exactly want to tell those codes which you have given in which files exactly to put these codes
I will show you that I installed the extension and on the forum categories I have a bum but on the header I have no hat and I have no snow as explained here why is it so?
Here's how it looks: https://imgur.com/Zz0DJnS
testing1
Post by testing1 »
3.2.1 Works great thanks :eusa_dance:
lopoto
Post by lopoto »
Not working for me too :wall:
lopoto wrote: 18 Nov 2017, 17:00 Not working for me too :wall:
Bit more info would help like style name phpbb version ?
lopoto
Post by lopoto »
martin wrote: 19 Nov 2017, 22:33
phpbb 3.2.1
style prosilver
