3.2.x Extensions Database 3.2 / 3.3Post Author 3.2.x
Post Author 3.2.x
Extension Name: Post Author 3.2.x
Author: dmzx special thanks to Sniper_E and martin
Displays clearly the Author/Time details in a post.
Post Author 3.2.x v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `postauthor`.
  4. Copy the `postauthor` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/postauthor/composer.json
  6. Look for `Post Author` under the Disabled Extensions list, and click its `Enable` link.
Re: Post Author 3.2.x
dmzx, martin and Sniper_E Thanx U :tumbsyes:
It is only to see in a topic, in the rest you do not see the extension Post author 3.2.x. is that correct?
https://www.jaantje.eu/forum320
Jaantje wrote: 02 Mar 2016, 22:56 it is only to see in a topic, in the rest you do not see the extension Post author 3.2.x. is that correct?
Yes correct like this:
On mine board I mean :rolling:
Jaantje wrote: 02 Mar 2016, 23:00 on mine board I mean :rolling:
Yes only in topics.
Buvaljub
    Linux Opera
Post by Buvaljub »
Post Author 3.2.x not working on phpBB-3.2.0-b1
Al the rest work
The Good, The Bad and The Ugly -> Linux, Windows and Dos.
Buvaljub wrote: 07 Mar 2016, 13:10 Post Author 3.2.x not working on phpBB-3.2.0-b1
Al the rest work
What style you tested on?
Buvaljub
    Linux Opera
Post by Buvaljub »
Buvaljub wrote: 07 Mar 2016, 13:33 Its work now
http://www.viertwintig.com
Null
Post by Null »
Is that the same "Topic Author" extension? If yes:
I had problems with it and posts width in bb3-mobi style. I solved that deactivating it, renaming:
ext/dmzx/topicauthor/styles/all
to
ext/dmzx/topicauthor/styles/prosilver
Null wrote: 01 Feb 2017, 05:02 Is that the same "Topic Author" extension? If yes:
to
No not the same, this will add the white background to poster in topics.
boldherri
Post by boldherri »
How do i set the display even in the titles discussions on the homepage as in this forum?
I can not find the settings
boldherri wrote: 02 Jun 2018, 17:43 Hi,
Thats done differently and not with this extension.
Look at css file on my homepage and look at a.lastsubject
I did it in css magic extension by martin
boldherri
Post by boldherri »
dmzx wrote: 14 Jun 2018, 10:21
Hi dmzx :)
I did and now they appear on the homepage, it's so much nicer, I like these small changes, I thank you very much :tumbsyes:
