3.2.x Extensions DatabaseNewest Members 3.2.x
<span class="qte-attr qte_32-qte">3.2.x</span>
Referrals: 48
Post by dmzx » Mar 1st, '16, 08:06
Extension Name: Newest Members 3.2.x
This extension shows the newest members instead of only one.
Under Gerneral=>Board Features=>Set value for newest members value can be set.
Newest Members 3.2.x v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `newestmembers`.
  4. Copy the `newestmembers` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/newestmembers/composer.json
  6. Look for `Newest members` under the Disabled Extensions list, and click its `Enable` link.
This topic has 11 replies
