3.1.x Extensions Database 3.1 / 3.2Did You Know
8 given 1
Did You Know
Extension Name: Did You Know
With this extension you can display texts in a small box at the top of the forum in a random order.
[travis]dmzx/Did-You-Know[/travis]
Added permissions in listener
Add version check ACP
Added Hide link
Added UCP option
  2. Unzip the downloaded release, and change the name of the folder to `didyouknow`.
  4. Copy the `didyouknow` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/didyouknow/composer.json
  6. Look for `Did You Know` under the Disabled Extensions list, and click its `Enable` link.
Nully
Re: Did You Know
Post by Nully »
Do you know? I see...nothing!
I inserted 3 texts in my language...(on local host, not on my board online).
Nully
Re: Did You Know
Post by Nully »
Yes, it works! :rolling:
I thought it will be showned on index...It is, but only when click on a forum title.
8 given 1
Re: Did You Know
Nully wrote:Yes, it works! :rolling:
:wink:
Null
Re: Did You Know
Post by Null »
May it be disable by the user?
Nully
Re: Did You Know
Post by Nully »
No.
Null
Re: Did You Know
Post by Null »
This extension is useful for begginers. After a while, should be desactivated by the user. Its useless and boring to receive same messages forever in the board, even you created 100 of them.
8 given 1
Re: Did You Know
Will take a look at UCP option.
8 given 1
Re: Did You Know
Null
Re: Did You Know
Post by Null »
Great!
Maybe an option "dont show it again" in message banner too? Otherwise it will be hard to users find this option in ucp.
1 given 1
Re: Did You Know
Null wrote:Great!
Null version 1.0.2 has this demo here your need to be logged in to see the hide.
Null
Re: Did You Know
Post by Null »
martin wrote:
Null wrote:Great!
Cool! Thanks!
8 given 1
Re: Did You Know
8 given 1
Re: Did You Know
Re: Did You Know
There is something missing in the acp language file
ACL_U_DID_YOU_KNOW (user roles)
