3.1.x Extensions Database 3.1 / 3.2Navbar
Navbar
Extension Name: Navbar
Special thanks to: martin & Sniper_E
Extra navbar select menu use dmzx_navbar_quick_links as event to add the links.
Change language file to whatever you want the call the navbar menu.
See "Games" menu in navbar here.
Navbar v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `navbar`.
  4. Copy the `navbar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/navbar/composer.json
  6. Look for `Navbar` under the Disabled Extensions list, and click its `Enable` link.
Null
Re: Navbar
Post by Null »
Download page is down.
Re: Navbar
Null wrote:Download page is down.
Updated :wink:
Ostdarva
Re: Navbar
Post by Ostdarva »
Awweee someone upload a screenie. I wanna see this in action!
Add me on Twitter[https://twitter.com/DarvaTV] ImageCheck me out on Twitch! [https://twitch.tv/darvatv] Image
Re: Navbar
First post updated :wink:
Ostdarva
Re: Navbar
Post by Ostdarva »
Awesome! :tumbsyes:
Null
Re: Navbar
Post by Null »
Have I to install dmzx_navbar_quick_links extension too?
Null
Re: Navbar
Post by Null »
Translation to Portuguese-Brazil: Download pt-br.rar from Sendspace.com - send big files the easy way
Translation to Spanish: Download es.rar from Sendspace.com - send big files the easy way
Re: Navbar
Null wrote:have I to install dmzx_navbar_quick_links extension too?
/ext/dmzx/navbar/styles/prosilver/template/event/overall_header_navigation_prepend.html
<!-- EVENT dmzx_navbar_quick_links -->
and place what you want, for example:
			<!-- IF S_USER_LOGGED_IN -->
				<li class="small-icon icon-ucp"><a href="{U_DM_SINKSHIP}">{L_DM_SINKSHIP}</a></li>
Nully
Re: Navbar
Post by Nully »
Is it different from arty/extranav?
Re: Navbar
No not the same as arty's as arty uses custom event in his themes.
i just rename the overall_header_navigation_append.html of what ever ext i want to dmzx_navbar_quick_links.html or i get double nav links 1 in quick link and 1 on navbar.
Custom links like this
<!-- IF S_USERNAME eq "martin" -->
<li class="small-icon icon-pm"><a href="." title="{L_}" role="menuitem">{L_}</a></li>
i had into the nav ext direct.
Nully
Re: Navbar
Post by Nully »
martin wrote: Custom links like this
:eyes2: So, I can use this code for my self and for other people?
I add:
<!-- IF S_USERNAME eq "people 1" -->
<!-- IF S_USERNAME eq "lady 2" -->
<!-- IF S_USERNAME eq "superman" -->
:question:
Re: Navbar
Sure you can but the correct way to link is like this
<li class="small-icon icon-faq" <!-- IF not S_USER_LOGGED_IN -->data-skip-responsive="true"<!-- ELSE -->data-last-responsive="true"<!-- ENDIF -->><a href="{U_FAQ}" rel="help" title="{L_FAQ_EXPLAIN}" role="menuitem">{L_FAQ}</a></li>
there is nothing stopping you from wraping an IF statment around custom code <!-- IF S_USERNAME eq "people 1" -->stinks<!-- ENDIF -->
example
<!-- IF S_USERNAME eq "people 1" --><li class="small-icon icon-faq" <!-- IF not S_USER_LOGGED_IN -->data-skip-responsive="true"<!-- ELSE -->data-last-responsive="true"<!-- ENDIF -->><a href="{U_FAQ}" rel="help" title="{L_FAQ_EXPLAIN}" role="menuitem">{L_FAQ}</a></li><!-- ENDIF -->
or
<!-- IF SCRIPT_NAME == "index" --><li class="small-icon icon-faq" <!-- IF not S_USER_LOGGED_IN -->data-skip-responsive="true"<!-- ELSE -->data-last-responsive="true"<!-- ENDIF -->><a href="{U_FAQ}" rel="help" title="{L_FAQ_EXPLAIN}" role="menuitem">{L_FAQ}</a></li><!-- ENDIF -->
the list can go on and on
Nully
Re: Navbar
Post by Nully »
Very interesting! Every day I learn something new :thumbup:
Re: Navbar
Here is one i'm using in my mchat body
<!-- IF S_USERNAME eq "Jaantje" --><span style="font-weight:bold; padding-top:-10px;">[phpBB Debug] PHP Notice: in file [ROOT]/ext/sniper/mobiledevice/event/listener.php on line 504: Undefined variable: status</span><!-- ELSE --><span style="font-weight:bold; padding-top:-10px;">  Jaantje is seeing a debug here only he can see it lol.</span><!-- ENDIF -->
it shows Jaantje
[phpBB Debug] PHP Notice: in file [ROOT]/ext/sniper/mobiledevice/event/listener.php on line 504: Undefined variable: status Fake phpbb debug error :rolling:
and every one else see's this
And this for a prank send button
<!-- IF S_USERNAME eq "Noname" -->	<input id="submit_button" type="button" class="button2" onclick="mChat.add(); myFunctions();" value="{L_MCHAT_ADD}" /><!-- ELSE -->
				<input id="submit_button" type="button" class="button2" onclick="mChat.add();" value="{L_MCHAT_ADD}"title="{L_MCHAT_SEND}" /><!-- ENDIF -->
