3.1 & 3.2 & 3.3 Extensions DatabaseCopyright in footer
Copyright in footer
Extension Name: Copyright in footer
Special Thanks to: martin
This extension adds copyright in footer.
- Changed code for startdate.
- Twig update.
Added years active.
Code update, validation version.
Copyright in footer v103
  2. Unzip the downloaded release, and change the name of the folder to `copyright`.
  4. Copy the `copyright` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/copyright/composer.json
  6. Look for `Copyright in footer` under the Disabled Extensions list, and click its `Enable` link.
This topic has 21 replies
Register Logout
