Extensions Database 3.1 / 3.2 ⇒ 3.1.x Total Active Extensions
3.1.x & 3.2.x
9 given 1
Extension Name: Total Active Extensions
Special Thanks to: martin
This extension shows total active extensions on index.
[travis]dmzx/Total-active-extensions[/travis]
  2. Unzip the downloaded release, and change the name of the folder to `totalavtiveext`.
  4. Copy the `totalavtiveext` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/totalavtiveext/composer.json
  6. Look for `Total Active Extensions` under the Disabled Extensions list, and click its `Enable` link.
Taka51
    Windows Vista Firefox
Re: Total Active Extensions
Post by Taka51 »
Hi dmzx
This is the French translation for this extension
quick to do but good lolll
Total Active Extensions Translate French 1.0.0 by dmzx.zip
WebDvdBdR - Page d’index
9 given 1
Taka51 wrote:Hi dmzx
Added :thumbup:
alfi0815
Post by alfi0815 »
Good ext.
but you can also list the extensions , or display ?
in next version??
1 given 1
alfi0815 wrote:Good ext.
in next version??
How would you display them when you have alot ?
alfi0815
Post by alfi0815 »
I mean that:
Show list of extensions
uruguayito
Post by uruguayito »
Maybe in pop up ;)
I'm a latin american man.
Spanish is my language.
alfi0815
Post by alfi0815 »
Taka51
    Windows Vista Chrome
Post by Taka51 »
Redmzx
French translation for this one too
Good Sunday
Total Active Extensions 1.0.0 Translate French@Taka51 ©Dmzx.zip
tamarin
Post by tamarin »
Thank you so much for the extension.
Here is the translation for Russian [ru] and German [de] languages. (s. attachment)
9 given 1
tamarin wrote:Here is the translation for Russian [ru] and German [de] languages. (s. attachment)
Added :thumbup:
Fast_Eddie
Post by Fast_Eddie »
After enabling this extension on my new board (was still setting it up) it broke the board with this error :
Fatal error: Uncaught exception 'ReflectionException' with message 'Class dmzx\totalavtiveext\event\listener does not exist' in /home/fasteddie43612/public_html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/DependencyInjection/RegisterListenersPass.php:101 Stack trace: #0 /home/fasteddie43612/public_html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/DependencyInjection/RegisterListenersPass.php(101): ReflectionClass->__construct('dmzx\\totalavtiv...') #1 /home/fasteddie43612/public_html/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/Compiler/Compiler.php(108): Symfony\Component\HttpKernel\DependencyInjection\RegisterListenersPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder)) #2 /home/fasteddie43612/public_html/vendor/symfony/dependency-injection/Symfony/Component/DependencyInjection/ContainerBuilder.php(576): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder)) #3 /home/fast in /home/fasteddie43612/public_html/vendor/symfony/http-kernel/Symfony/Component/HttpKernel/DependencyInjection/RegisterListenersPass.php on line 101
At this point I can do nothing, but thought i'd post this up encase there is a way to save it before I start all over! :yikes:
Edit:
With help from Zardos, I got it back! just deleted the ext. and refreashed. Thanks dude!
:beers: Retirement 2024!
