3.1 & 3.2 Extensions Database 3.1 / 3.2File Download
Re: File Download
Fr0sTt wrote: Jan 12th, '16, 19:07 He doesn't work, I attach file and not..
What version of phpbb do you use?
EDIT: :thumbup:
Fr0sTt
Re: File Download
Post by Fr0sTt »
Sorry, I'm confused his work :D
samemmerde
Re: File Download
Post by samemmerde »
Good evening
I installed the extension and it is fine.
I put pictures, resize my forum
and attachment I put the original picture rar file.
The guests can not download the original picture without enregsitré, but I noticed that he could not see the picture either.
Is there a solution for the guests to see the photo?
Thank you
Bonsoir
J'ai installé cette extension et elle est très bien.
Je mets des photos, rédimensionnées sur mon forum
et en pièce jointe je mets la photo original en fichier rar.
Les invités ne peuvent pas télécharger la photo original sans être enregsitré, mais j'ai remarqué qu'il ne pouvait pas voir la photo non plus.
Y a t il une solution pour que les invités voient la photo ?
Merci
Anuj Dhawan
Re: File Download
Post by Anuj Dhawan »
Attachments are showing up twice when using this extension.
I have noticed it lately only but it looks like it's been happening for quite some time on my Board. Board is enough, if not heavily, modified so I was not sure initially which extension might be causing it. Have started a thread for this on phpbb.com and from a hint there, it looks like (unfortunately) disabling "File Download" extension makes it work and that's something I would not like to do.
Any pointer to resolve this will be a great help. As of now this extension is disabled.
Re: File Download
Thanks, just noticed this ext.
Works OK for me on 3.1.9
Re: File Download
Double downloads ? see here viewtopic.php?f=49&t=1000&start=15#p3715
Anuj Dhawan
Re: File Download
martin wrote: Jul 16th, '16, 13:41 Double downloads ? see here viewtopic.php?f=49&t=1000&start=15#p3715
I'm not sure if it helped or not but bmp images still shows twice! :???: Need to check other extensions too but it's late in night here in India.
Re: File Download
I see the problem try this file there is 2 ext's in the folder that is needed.
ext.zip
then end result is this
Note only one download ?
Anuj Dhawan
Re: File Download
Hi Martin,
1. I have unloaded "ext.zip" and unzipped it. Can see there are two extension - "downloadlog" and "filedownload" as you said. As I'm using "Upload Extension" to upload the extensions, zipped them individually and uploaded. With Donloadlog ext I'm getting the following error:
2. Though the "filedownload" from the last post seems to solve the "double attachment" problem for ".bmp" too.
Re: File Download
What phpbb version you using ?
Anuj Dhawan
Re: File Download
martin wrote: Jul 18th, '16, 13:08 what phpbb version you using ?
phpBB 3.1.9 .
Re: File Download
Ahhh i posted for 3.2 but should also work.
Anuj Dhawan
Re: File Download
martin wrote: Jul 19th, '16, 10:04 ahhh i posted for 3.2 but should also work.
Tried again with "Upload Extensions" extension - but got the same error; will try with FileZilla later. Can't try it from this network I'm logged in to. No FTP is allowed with in this proxy here.
ircfc
Re: File Download
Post by ircfc »
Are you good at?
There is a problem with this plugin
When the image was joined in threads
I write threads in the thread send two identical images of the attached image appears
Please check and correct the problem!
This problem only image files that I attach a few examples (in Persian)!
Bye
Re: File Download
