3.2.x Extensions Database 3.2 / 3.3Top Stats 3.2.x
Re: Top Stats 3.2.x
jan_2017 wrote: 15 Jan 2018, 00:24 Yes , thats´s how i did it.
But , the number "5" or "10" (changeable in ACP) stands before the word "The".
Now i read in the window "Top Stats":
" 10 the most viewed topics "
it must be right:
"the 10 most viewed topics"
I hope you know what i mean :wink:
Bye Jan
I know what you mean...
The prosilver/template/top_stats_body.html
<dt>{TSMVT_NUMBER} {L_MOST_VIEWED}</dt>
That gives you the "10" and "Most viewed topics" from the lang file.
You would need another lang entry for "The" - top_stats_body.html
<dt>{L_THE_MOST} {TSMVT_NUMBER} {L_MOST_VIEWED}</dt>
common.css
	'THE_MOST'                  => 'The',
	'MOST_VIEWED'               => 'most viewed topics',
meis2m
Re: Top Stats 3.2.x
Post by meis2m »
Hi is it possible show the prefix of this extension in top state?
https://github.com/ErnadoO/qte
Re: Top Stats 3.2.x
meis2m wrote: 20 Jan 2018, 11:19 Hi is it possible show the prefix of this extension in top state?
Do you mean prefixes in recent topics?
bye Jan
meis2m
Re: Top Stats 3.2.x
Post by meis2m »
Yes exactly
Re: Top Stats 3.2.x
I also wish that the prefixes appear there.
kraminoft
    Ubuntu Firefox
Re: Top Stats 3.2.x
Post by kraminoft »
How to hide admins ,mods and bots from Most active users?
kamyk25
Re: Top Stats 3.2.x
Post by kamyk25 »
Hello guys! I installed this ext and I like it so much, but I have small problem with it.
After this I saw that top stats are loading with delay. Try to scroll down this site to place where I moved top stats and pres f5 few times. Can You help me to delete that delay? I can pay You of cours if it is big problem.
One more thing - I dont want top stats on all subpages I want them only on main page. Is it possible to remove top stats from all pages except main page?
One more important thing which I discovered now: 10 Most active forums is not working correctly. For example first forum in this stats is "Aktualności ze świata używek" with 249 posts. But in real this forum has 688 posts and they shouldnt be first, becuase 2900+ and 1000+ posts forums...
All other stats seems to work correctly. I tried to turn off 10 most active forums, but it isnt reason of delay, because without it all top stats are loading still with 5 sec delay.
Kind Regards
Re: Top Stats 3.2.x
Is it possible to have more than 3 rows in recent topics panel ?
I looked in css but I can't seem to find a place to adjust that.
THX
Sorted :)
mortalites
Re: Top Stats 3.2.x
Post by mortalites »
I saw some brief discussion on this but still not sure if this can be done. I would like to have the top stats display inside the Fancy Stats Extension by Martin. Under the Statistics section at the bottom of the Fancy Stats block. Any help would be appreciated.
spinecki
Re: Top Stats 3.2.x
Post by spinecki »
Hi, although I set permission for guests to see "topstats", they do not appear on site.
I see them only when i am logged in. Any ideas what can go wrong?
Re: Top Stats 3.2.x
spinecki wrote: 04 Mar 2019, 16:08 Hi, although I set permission for guests to see "topstats", they do not appear on site.
Open top_stats_body.html and delete <!-- IF S_USER_LOGGED_IN --> and the last <!-- ENDIF -->
and if needed:
Open recent_active_body.html and delete <!-- IF S_USER_LOGGED_IN --> and the last <!-- ENDIF -->
Clear cache in ACP after that.
spinecki
Re: Top Stats 3.2.x
Post by spinecki »
dmzx wrote: 04 Mar 2019, 16:18
and if needed:
Ok, it worked (of course). Thanks!
spinecki
Re: Top Stats 3.2.x
Post by spinecki »
Is there a way for excluding categories/forums/topics from being shown in "most viewed" and "most replied topics"?
Re: Top Stats 3.2.x
spinecki wrote: 04 Mar 2019, 19:05 Is there a way for excluding categories/forums/topics from being shown in "most viewed" and "most replied topics"?
For now not, It works like this now: If you have read access the topics are shown, if not no show.
Re: Top Stats 3.2.x
