3.2.x Extensions Database 3.2 / 3.3 ⇒ Top Stats 3.2.x
seacoast
Re: Top Stats 3.2.x
I'm not sure. Weird. I am using Feed Post Bot extension. hmm...
Re: Top Stats 3.2.x
I am not sure how a topic is concidered to be an active topic. I guess there is a time passed since it had a reply. But for 7 pages of topics to be active you would have to have some kind of activity, in all of those topics.
Maybe in actuality you only have 2 of those topics that have had recent responses for them to be active. Test it by posting some test responses in some of those topics and see if you get more active topics to show in this extension.
[ Post made via Samsung Galaxy S5 Active ]
seacoast
Re: Top Stats 3.2.x
Yes it worked. It came up.
When I choose active topics from the quick menu and choose 1-day instead of 7 days, it goes down to 2 pages. I'm wondering now if there is a setting somewhere in the config for this. Can't find one.
Re: Top Stats 3.2.x
I wouldn't know. Maybe this extension has a setting in the core files, or listener.php file. I'm not sure.
seacoast
Re: Top Stats 3.2.x
Ok thanks for your help. I'll figure something out. ;)
eunaumtenhoid
Re: Top Stats 3.2.x
* Brazilian Portuguese translation by eunaumtenhoid (c) 2017 [ver 1.0.1]
https://github.com/phpBBTraducoes/topstats
Re: Top Stats 3.2.x
What part of top stats would you like in fancy stats ?
Like this ? and with collapse On my site with just 2 enabled
Re: Top Stats 3.2.x
Hello Martin
I would like to have additionally indicated this with:
Everything except Bots and Recent Topics.
Bye Jan
Re: Top Stats 3.2.x
Edited my post with images regards bots and topic if you set then to off in ext acp they wont show.
Re: Top Stats 3.2.x
Hi Martin.
In your post the second picture. Collapse looks good.
Re: Top Stats 3.2.x
Open ext/dmzx/topstats/styles/prosilver/template/event/index_body_forumlist_body_after.html
and rename it too index_body_block_stats_append.html and purge cache. (make sure your in acp before you rename it or your get an error)
Re: Top Stats 3.2.x
martin wrote: 14 Jan 2018, 23:20 Open ext/dmzx/topstats/styles/prosilver/template/event/index_body_forumlist_body_after.html
Thank you very much
Now i see a little problem in translation to german.
If i open in ext/dmzx/topstats/language/de/common.php i see a wrong translation.
Example:
Line 40 "MOST_VIEWED" ... in german it looks better if the article before the word.
It could mean better "THE MOST_VIEWED"
How can i change the line in common.php?
It should be there like that: "The 10 most viewed topics" - in german "Die 10 meist gesehenen Themen"
Bye Jan
Re: Top Stats 3.2.x
'MOST_VIEWED' => 'The most viewed topics',
Re: Top Stats 3.2.x
Yes , thats´s how i did it.
But , the number "5" or "10" (changeable in ACP) stands before the word "The".
Now i read in the window "Top Stats":
" 10 the most viewed topics "
it must be right:
"the 10 most viewed topics"
I hope you know what i mean
Bye Jan
it must be right:
Bye Jan
