3.2.x Extensions Database 3.2 / 3.3Navbar 3.2.x
Re: Navbar 3.2.x
Voice4Vision wrote: 16 Aug 2018, 08:38 The BBcode was a bit of a challenge, since it was never fully implemented into phpBB 3.2
You got me interested in adding that bbCode link.
						<li <!-- IF not S_USER_LOGGED_IN -->data-skip-responsive="true"<!-- ELSE -->data-last-responsive="true"<!-- ENDIF -->>
							<a href="{U_FAQ}" rel="help" role="menuitem">
								<i class="icon fa-question-circle fa-fw" aria-hidden="true"></i><span>{L_FAQ}</span>
							</a>
						</li>
					<!-- IF S_BBCODE_ALLOWED -->
							<a href="./help/bbcode" rel="help" role="menuitem">
								<i class="icon fa-code fa-fw" aria-hidden="true"></i><span>{L_BBCODE_GUIDE}</span>
							</a>
						</li>
spaceworld
Re: Navbar 3.2.x
Post by spaceworld »
it is complicated ! I do not understand anything!
I'm too scared to make a mistake !!
:yikes: :yikes: :yikes: :yikes:
kaptangula
Re: Navbar 3.2.x
Post by kaptangula »
Alas :rolling:
simple is not difficult
spaceworld
Re: Navbar 3.2.x
dmzx wrote: 06 Feb 2017, 20:57 To add some links use the dmzx_navbar_quick_links as an event.
So rename for example overall_header_navigation_append.html from an extension where the navbar link is in to dmzx_navbar_quick_links.html
then the link is shown into the menu.
I don't understand that ... ca you explain more ! What I have to change or put exactly ! I'm totaly lost ! sorry to be so stupid !
Your mod is so great ! and I can't use it because i'm a BIG nooooooob !!!!
:buigen: :buigen: :buigen: :buigen:
kaptangula
Re: Navbar 3.2.x
Do you want to add ney into your sister navbar
play and do whatever you want
open
navbar
editt
puzzles
open
styles/prosilver/evet/
edit
<!-- IF S_USER_LOGGED_IN --><li class="small-icon icon-faq"><a href="{U_DM_PUZZLE}" title="{L_PUZZLE_NAVIGATION}">{L_PUZZLE_NAVIGATION}</a></li>
if(document.all&&document.namespaces&&!window.opera) {
if(document.namespaces['v']==null) {
var e=["shape","shapetype","group","background","path","formulas","handles",
"fill","stroke","shadow","textbox","textpath","imagedata","line","polyline",
"curve","roundrect","oval","rect","arc","image"];
var s=document.createStyleSheet();
for(var i=0; i<e.length; i++) {
s.addRule("v\\:"+e,"behavior: url(#default#VML);");
document.namespaces.add("v","urn:schemas-microsoft-com:vml");
</script>
<script type="text/javascript" src="{ROOT_PATH}ext/dmzx/puzzle/puzzles/snapfit.js"></script>
Add contents to the above
spaceworld
Re: Navbar 3.2.x
kaptangula wrote: 06 Nov 2018, 18:45
</script>
Thx so I have to put this code
</script>
to this template "dmzx_navbar_quick_links.html"
Really ?
Re: Navbar 3.2.x
:rolling:
Exabot
    Mac OS X Firefox
Re: Navbar 3.2.x
Post by Exabot »
Estonian translation.
et.zip
