Re: Youtube Videos Gallery
SpIdErPiGgY wrote: 02 Mar 2025, 21:53 ACP / Video titles
Clicking on the "Sync" function:
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/youtubegallery/controller/admin_controller.php on line 330: Trying to access array offset on null
[phpBB Debug] PHP Warning: in file [ROOT]/ext/dmzx/youtubegallery/controller/admin_controller.php on line 331: Trying to access array offset on null
SQL ERROR [ mysqli ]
Column 'video_duration' cannot be null [1048]
SQL
UPDATE phpbb_video SET video_description = '<t></t>', video_duration = NULL WHERE video_id = 8
BACKTRACE
Enter a description the ext was tested and found to be working.
SpIdErPiGgY
    Android Firefox
Post by SpIdErPiGgY »
martin wrote: 03 Mar 2025, 01:33
SQL
BACKTRACE
I did... 😁 but the desctiotion field is empty in acp
🌐 phpBB Extensions in Dutch
💚 Support this project on Ko-fi
Does not matter if a description is filled out or not see image above.
Check your api is working enable posting in chat if the name posts then your api key is good if not go make a new api key.
SpIdErPiGgY
    Android Firefox
Okay I had to disable the ext, and remove data.
After a new install, everything is working.
When just updating to the new version, It did not show the duration time of the videos. That was the SQL error.
In the template/video_body.html template that starting first &bull; made the titles look off.
Maybe you could add an if statement around that on the next release so my face cheek want twitch when looking at it. :lol:
<p>{% for videocat in loops.videocat %}{% if not videocat.S_FIRST_ROW %} &bull; {% endif %}<a href="{{ videocat.U_CAT }}" id="cat{{ videocat.VIDEO_CAT_ID }}">{{ videocat.VIDEO_CAT_TITLE }}</a>{% endfor %}</p>
Video Categories
nou nou
Post by nou nou »
When trying to enable the extension (v1.1.1)
Purge the boards cache then enable it and then purge after.
nou nou
Post by nou nou »
Thanks - doesn't work, I still get the same error.
The extension is in the disabled extensions list and there is data, and when I try "delete data" I get this:
this seems to be the added data:
What would be the best way to go about this now?
Xxxbennyxxx
Post by Xxxbennyxxx »
SpIdErPiGgY wrote: 03 Mar 2025, 01:34
SQL
BACKTRACE
Same problem with version 1.1.1, only a complete reinstallation solves this problem
Xxxbennyxxx
Just a quick question: I think the font size of the description/content of the video is very large. Looks like it's just copying this from YouTube. Can i hardcode this font size in the CSS ?
nou nou
Post by nou nou »
:mml:
Leftover database tables from a previous restore - did a fresh one, and tadaaa!
All good!
(but I'd be happy to learn how to troubleshoot/fix this without starting over... I removed any phpbb_video tables and reference to the extension in phpbb_ext but it still didn't work, some migration error I couldn't get rid of)
Thanks!
nou nou wrote: 13 Mar 2025, 22:31 Screenshot 2025-03-13 213532.png
:mml:
All good!
Thanks!
on holiday now back the 21th, will explain then
d3ath2435
Post by d3ath2435 »
Thanks for the EXT, but I've some issues with it
is not showing the stats from youtube
Also I cannot edit Titles, descriptions etc?
Also when I push the button Resync
nou nou
Post by nou nou »
Working great so far! Will have to do some CSS changes for my style but that was to be expected.
I have a couple of requests if I may...
- Subcategories or the ability to assign multiple categories to a video. I can see libraries grow to where they really will need more specific ways of sorting/searching.
- The ability to change the order of categories in the ACP (exactly like how you can move the order of forums, for example)
- The order displayed in the videos page is the inverse of the order in the drop-down list when adding videos - could they both follow the ACP order?
Please and thank you, enjoy your holiday!
