Extensions Database 3.1 / 3.2 ⇒ 3.1.x Note Extension
3.1.x & 3.2.x
1 given 1
Re: Note Extension
This is for 3.1 not 3.3
Just tested on 3.3.7 and it works.
Re: Note Extension
clight77 wrote: 01 Apr 2022, 04:07 I am on 3.3.7 and my version works :)
It works. Only if you give Advanced BBcode Box doesn't work.
1 given 1
Re: Note Extension
There is your issue your trying to use 2 bbcode exts both exts change the template file.
Fast_Eddie
    Windows 7 Edge
Re: Note Extension
Post by Fast_Eddie »
Just tested on mine and it installed but no bbcode display. Will re-check permissions ....etc...
:beers: Retirement 2024!
