3.1 & 3.2 Extensions Database 3.1 / 3.2Topic Author
Re: Topic Author
Mommike wrote: 9 years ago
dmzx wrote: 9 years ago
Mommike wrote: 9 years ago Thank worked fine!
One more question. It capitalize every word. How do modify that it showing exactly this way, as I write inside ACP.
This should not be, what did you add in ACP?
Sorry, my bad. It is under the extensions tab, Topic author - Adjust topic author text. How to modify that it showing the text exactly this way, as I write inside this field.
What text did you add?
Mommike
Re: Topic Author
Post by Mommike »
I write there - "Teema autor", but inside topic shows me "Teema Autor". Every word is capitalized.
Re: Topic Author
Open topicauthor.css
Delete:
text-transform: capitalize;
And clear cache.
Mommike
Re: Topic Author
Post by Mommike »
dmzx wrote: 9 years ago Open topicauthor.css
Delete:
And clear cache.
Thanks! :tumbsyes:
fliper4o
Post by fliper4o »
Hey,
I really like your extensions ! Thank you :)
Just two questions, if you don't mind :)
1st How can I delete the field
Select colour: Click field to select with colour picker.
Or Can you make an option like Yes/No (if ppl want that field to be colored or they want it blank(just text) as)
2nd Can I change the position if it in profile as some guy mentioned but I would add after the rank ether.
Just as it shows the picture below !
mikeablah wrote:It's below the name and avatar which would be great to have! Thanks so much.
Edit:
For v1.0.2 dmzx/styles/all/template/event/viewtopic_body_avatar_after.html
dmzx wrote:In the viewtopic_body the EVENT is standard above.
You can place the <!-- EVENT viewtopic_body_avatar_after --> on a other place in the viewtopic_body but then you change the original .html file.
you have to clear the cache if you change it.
What to change to looks like what @mikeablah quoted
https://wiki.phpbb.com/Event_List
Seems possible to me as the examples proves it. Just need some help to do it so.
Thank you!
fliper4o
Re: Topic Author
Post by fliper4o »
Bump
As, mikeablah, said.
How can I change the position.
From
To
* @package Topic Author
* @author dmzx (www.dmzx-web.net)
* @copyright (c) 2014 by dmzx (www.dmzx-web.net)
* @license http://opensource.org/licenses/gpl-license.php GNU Public License
</div>
<div>
<br /><!-- IF postrow.S_TOPIC_POSTER --><strong style="color: #FF0000;">{L_TOPIC_AUTHOR}</strong><!-- ENDIF -->
I'm using v1.0.2 on phpBB 3.2.1 with prosilver 'cuz honestly I don't like the "Added text colour field" & I can't even get rid of it with Yes/No option on the newest version.
Thanks!
Re: Topic Author
You just change the name of the event file to where ever you would like it to show.
You would also need to have another tab open of the acp so you can purge the cache or your see an error page.
fliper4o
Re: Topic Author
Post by fliper4o »
fliper4o wrote: 9 years ago Image
& this is
viewtopic_body_postrow_rank_after
or
something else?
martin wrote: 9 years ago Image
//I've changed
topicauthor\styles\all\template\event from viewtopic_body_avatar_after.html to viewtopic_body_postrow_rank_after.html
And lol the f*ck
But the place of "Topic Author" aka "Original Poster" is on the right place as it should be(in the original pic). Right before Posts: & Joined:
I'll need some help.
Re: Topic Author
If you put it there you may need a <dd></dd> wrapped around the ext template codes and remove that </div><div> line.
ext/dmzx/topicauthor/styles/all/template/event/viewtopic_body_postrow_rank_after.html
<!-- IF postrow.TOPICAUTHOR_ENABLED and postrow.S_TOPIC_POSTER -->
<dd class="topic-author" style="background: #{postrow.TOPICAUTHOR_COLOUR}; color: #{postrow.TOPICAUTHOR_TEXT_COLOUR};">{postrow.TOPICAUTHOR_TEXT}</dd>
I change the code a little. I was getting a empty bar on users not the topic author when testing.
fliper4o
Re: Topic Author
Post by fliper4o »
Topic Author 1.0.2, phpBB 3.2.1 hm? When I try your example I've got nothing it's like disabled, nothing shows, nothing see, enable/disable is the same.
That's the original renamed viewtopic_body_postrow_rank_after.html
</div>
<div>
Edit:
<!-- IF postrow.S_TOPIC_POSTER --><dd <strong style="color: #FF0000;">{L_TOPIC_AUTHOR}</strong></dd><!-- ENDIF -->
Result:
P.P. Tell me if there is something wrong, issues, errors, etc 'cuz I do NOT understand coding, much!
Re: Topic Author
Sorry I'm testing phpBB 3.2.1 with topicauthor 1.0.4 hold on a minute and I'll look at the other versions.
Wait a minute are you running phpBB 3.2.1? You need Topic Author 1.0.4
This is the original 1.0.2 viewtopic_body_avatar_after.html
<!-- IF postrow.TOPICAUTHOR_ENABLED -->
</div><div>
<br /><!-- IF postrow.S_TOPIC_POSTER --><div class="topic-author" style="background: #{postrow.TOPICAUTHOR_COLOUR};">{postrow.TOPICAUTHOR_TEXT}</div><!-- ENDIF -->
fliper4o
Re: Topic Author
Post by fliper4o »
In 1.0.4 I dislike
Added text colour field by ...
That's why I'm using the old 1.0.2 version.
If you would like to help me get rid of the color I'm willing to use the newwest version 1.0.4 :)
Transparent can I make it?
Edit:
Naahhh...it looks awful to me sorry to say that. Even IF the field Select colour: is empty!
Compare:
Probably I'll back to version 1.0.2 as best option so far, thanks!
Re: Topic Author
Sure I'll help you any way I can. Sorry I had to step out for a bit.
Now I was testing out 1.0.4 http://sniper-e.com/viewtopic.php?f=4&t=7
This is my test. Topic Author Rank After
I actually like it better as Rank Before
I can install 1.0.2 and see what it is you want to change. The color is in the user color I think, not sure of that version.
What exactly did you want to change in version 1.0.2? The color in 1.0.4 is set in the topicauthor.css
fliper4o
Re: Topic Author
Post by fliper4o »
Hm...
I'm currently using 1.0.2, just tried 1.0.4 & back to 1.0.2. The picture(s) Before/After are 1.0.2.
That is what I've done viewtopic.php?p=17883#p17879
Check the pic in my last post as it says "After" That I would like it to be on 1.0.4. What have to change on topicauthor.css
The pic after, the "After" pic is 1.0.4 with NO colour in acp settings.
I want to be like on the left image(1.0.2) when I try (1.0.4) I do NOT like it like that.
Image Image
Thanks!
Re: Topic Author
Topic Author without the button, just text in version 1.0.4
See if this Is that what you want?
I have 1.0.4 installed and in the acp I changes the text color to red instead of purple.
You choose your preferred color.
These were my edited files.
<dd class="topic-author" style="color: #{postrow.TOPICAUTHOR_COLOUR}">{postrow.TOPICAUTHOR_TEXT}</dd>
topicauthor.css
.topic-author {
	margin: 0;
	font-size: 9px;
	font-weight: bold;
@media (max-width: 700px) {
	.topic-author {
		margin: 1px 4px 1px 40px;
And you know the text "Topic Author" is in the language file if you want it to say "Original Poster"
