3.3.x Extensions Database 3.2 / 3.3Topic Image
Re: Topic Image
This is format I use in subject area when posting...
https://www.imdb.com/title/tt1517260/
[nfo]
This posting is brought to you by nzbforyou.com
Are you tired
Of NZB's being dead after 24 hours!!!
Of every site having all of the same DEAD NZB's!!!
Of every site having all the same content!!!
If so, come visit us at:
https://www.nzbforyou.com/nzbforyou.php
Movies, Full TV seasons, Documentaries and MUCH MORE!
ENJOY!
This postings content:
The Host 2013 720p BluRay x264-x0r nzb4u.mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 2.82 GiB
Duration                                 : 2 h 5 min
Overall bit rate                         : 3 233 kb/s
Movie name                               : The.Host.2013.720p.BluRay.x264-x0r
Encoded date                             : UTC 2018-02-28 01:47:13
Writing application                      : mkvmerge v7.7.0 ('Six Voices') 64bit built on Mar  1 2015 01:50:05
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4
Format settings                          : CABAC / 8 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 8 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 2 560 kb/s
Width                                    : 1 280 pixels
Height                                   : 720 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.116
Stream size                              : 2.24 GiB (79%)
Writing library                          : x264 core 142 r2389 956c8d8
[img]
https://m.media-amazon.com/images/M/MV5BMjMwNDg1MTAzNV5BMl5BanBnXkFtZTcwNTk5ODI3OA@@._V1_UX182_CR0,0,182,268_AL_.jpg
[/img]
[/nfo]
NOTE: This may be a password protected archive.
brahim 101
Re: Topic Image
Post by brahim 101 »
medic
Re: Topic Image
Post by medic »
The topic i use has 3 images is there a way th extesion to grab the second one not the first
Helios
Re: Topic Image
Post by Helios »
Italian Language
[download=orange]Download-link IT.rar
https://rg.to/file/93519780cf4131ca9d105a1f890b950a/it.rar.html
[/download]
Re: Topic Image
Helios wrote: 20 Jul 2021, 00:36 Italian Language
[/download]
Here is zip file.
Italian.zip
Xxxbennyxxx Online
Re: Topic Image
Post by Xxxbennyxxx »
The intention is that the random image is not on the index but only at the top of the forum
https://www.ana4life.be/viewforum.php?f=129
is placed. How do I finish this? Thanks in advance!
Re: Topic Image
Topic image, won't load selected forums that it grabs images from. Just started the other day.
Any ideas?
THX
Re: Topic Image
Re: Topic Image
Topic Image_1.0.1-Slovenin.zip
Re: Topic Image
Hey DM
For some reason on my site when forums are selected to draw from it takes forever for the forums to load, this started about 2 months ago, but I know you are busy, so if you get time please have a look, you are still Admin on my site...
gep
Re: Topic Image
Post by gep »
Thank you for this extension
Banned
Banned
Re: Topic Image
You can find a french translation of 1.0.1 version here
Alpha
Re: Topic Image
Post by Alpha »
Hi, top your extensions, I love it, I wanted to ask if there is a setting or code or anything to enlarge the images, thanks my friend.
Sorry for my English
Person ??
limp8976
Re: Topic Image
Post by limp8976 »
Hello, how can I make the image look larger since it only allows you to enlarge it up to 120?
Beer
Re: Topic Image
Post by Beer »
Parse error: syntax error, unexpected ')', expecting variable (T_VARIABLE) in H:\OSPanel\domains\sitetest\forum\ext\dmzx\topicimage\cron\prune_topicimage.php on line 34
Works if removed:
	public function __construct(
		config $config,
		helper $helper,
		$this->config			= $config;
		$this->helper 			= $helper;
