3.2 & 3.3 Extensions Database 3.2 / 3.3Editor extension
Re: Editor extension
Editor extension_1.0.2-Slovenian.zip
Onnozel Manneke wrote: 04 Oct 2021, 15:12 Okay I need some help on how to replace php code with this ext.
So lets say in /includes/acp/acp_email.php I need to add $messenger->set_mail_html(true); below this code $messenger = new messenger($use_queue);
How can I do that?
Would this be close?
		$replacements = array(
			'files' => array(
				0 => '/includes/acp/acp_email.' . $this->php_ext,
			'searches' => array(
				0 => array(
					0 => '				$messenger = new messenger($use_queue);',
			'replaces' => array(
				0 => array(
				$messenger->set_mail_html(true);',
Oh shit that question was years ago :lol: my bad. But does this code look right?
Quick question...
Does Editor extension work on editing style/prosilver/template/files and include/files like in the above post or can it only edit extension files?
exemplary
    Windows 8.1 Firefox
Post by exemplary »
I installed this on 3.3.13 and now I can't uninstall. It gives a blank page while clicking disable > Disable button.
Any solution ?
Thank you.
Dont use the ext uploader to disable the ext use phpbb's built in ext manager.
exemplary
    Windows 8.1 Firefox
Post by exemplary »
martin wrote: 14 Sep 2024, 01:54 Dont use the ext uploader to disable the ext use phpbb's built in ext manager.
Thank you for the the reply.
I am using phpbb's ext manager. I tried on localhost, and it gets uninstalled immediately, but on my live website, it takes time and then gives a blank page. If I change folder name (editor under dmzx) on my host, the ACP goes blank. Could it be conflicting with other extensions ? I am using all official extension of phpbb. This is a fresh installation, set up few days ago and havn't made many changes.
When i tried to make topic normal or sticky i see lot of errors but one of them is
Deprecated:  Optional parameter $replacements declared before required parameter $revert is implicitly treated as a required parameter in /var/www/html/ext/dmzx/editor/editor.php on line 44
Little help??
