3.1 & 3.2 & 3.3 Extensions Database 3.1 / 3.2Countdown Header
Re: Countdown Header
el torro wrote: 25 Feb 2018, 20:00 Hi, is it difficult to put the bar above the footer?
Rename the event file to overall_footer_page_body_after.html and clear server cache.
Or try overall_footer_content_after.html for the event name. See where you want it.
el torro
    Ubuntu Firefox
Post by el torro »
Event file??
Yes
el torro
    Ubuntu Firefox
Post by el torro »
There are 3 files inside the event folder, but I don't see a event file?
In this extension, styles/prosilver/template/event/overall_header_page_body_before.html
rename to, styles/prosilver/template/event/overall_footer_page_body_after.html
NOTE: Be in ACP in another tab so you can clear server cache after renaming that file.
el torro
    Ubuntu Firefox
Post by el torro »
OK now I understand, thank you very much :tumbsyes:
A
Hartenheer
Post by Hartenheer »
Thank you, we succeeded
How can i make clickable this header?
cuz i cannot click when the event is complete
see here i put this topic but can't click on it
ivailo95 wrote: 27 Jul 2018, 07:25 how can i make clickable this header?
you can click on it when countdown is completed.
dmzx wrote: 30 Jul 2018, 14:54
look here i put a link with topic i posted before seconds
how can i fix this?
