3.2.x Extensions Database 3.2 / 3.3Navbar 3.2.x
lopoto
Re: Navbar 3.2.x
Post by lopoto »
As you write, it seems so simple, and I'm immune to IT :D
but thanks you are trying :beers:
Re: Navbar 3.2.x
HsnCnKly wrote: 24 Mar 2018, 15:08 How can I do like this at simplisity theme. I need to add setforumwidth and readmemberspm extensions. Sorry for my bad english, help, please.
I took dmzx/navbar/styles/prosilver/template/event/overall_header_navigation_prepend.html template and added code at the bottom.
<!-- IF not S_IS_BOT and S_USER_LOGGED_IN -->
<li id="quick-links" class="quick-links responsive-menu dropdown-container<!-- IF not S_DISPLAY_QUICK_LINKS and not S_DISPLAY_SEARCH --> hidden<!-- ENDIF -->" data-skip-responsive="true">
<a href="#" class="responsive-menu-link dropdown-trigger">
	<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{{ lang('NAVBAR_LINKS') }}</span>
</a>
	<div class="dropdown hidden">
		<div class="pointer"><div class="pointer-inner"></div></div>
		<ul class="dropdown-contents" role="menu">
			<!-- EVENT dmzx_navbar_quick_links -->
		</ul>
	</div>
</li>
<li id="extensions-links" class="quick-links responsive-menu dropdown-container" data-skip-responsive="true">
	<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{{ lang('EXTENSIONS') }}</span>
</a>
			<!-- EVENT dmzx_navbar_extensions -->
		</ul>
	</div>
</li>
That created dmzx's Games drop down menu and an Extensions drop down menu.
Then I renamed all of the event templates in my extension's event/ folder to dmzx_navbar_extensions.html
That's it folks. It does not get any simpler than that.
And I found out that dmzx's code in the <ul class="dropdown-contents-navbar" role="menu"> caused the little space in the drop down.
I changed that line to <ul class="dropdown-contents" role="menu"> and all the links showed up fine.
Re: Navbar 3.2.x
To be fair its dead simple
just rename the overall_header_navigation_append.html thats in all exts to dmzx_navbar_quick_links.html
lopoto
Re: Navbar 3.2.x
Post by lopoto »
@martin - working ! :eusa_dance:
I now have a few ext in Games. And how to make a second bar next to it, let's say photo and give it to fotoupload?
Re: Navbar 3.2.x
Add some codes at the bottom of dm's template like I showed you above.
<li id="photo-links" class="quick-links responsive-menu dropdown-container" data-skip-responsive="true">
	<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{{ lang('PHOTOS') }}</span>
</a>
			<!-- EVENT dmzx_navbar_photos -->
		</ul>
	</div>
</li>
Then use dmzx_navbar_photos.html event template names to insert the links to them.
WTF is going on in here. I said the same thing.
Sniper_E wrote: 12 May 2018, 00:09The event template is named overall_header_navigation_prepend.html you can rename that to dmzx_navbar_quick_links.html
This will move your game link into your new "Games" drop down menu.
But Martin comes in and says it and people get it. WTH :guns:
lopoto
Re: Navbar 3.2.x
Post by lopoto »
THX Sniper :beers: and martin , I could not help myself, you are always helpful :eusa_dance: :tumbsyes:
Re: Navbar 3.2.x
I posted it back on page one :rolling: no one read it.
luca17000
Re: Navbar 3.2.x
Post by luca17000 »
Yes yesssss yessssssssssssss !!!!! :dance: :dance: :dance: :eusa_dance: :eusa_dance: :eusa_dance: :eusa_dance:
THANK YOU TO ALL, BEAUTIFUL WORK !!!! :beers: :beers: :beers:
Re: Navbar 3.2.x
martin wrote: 12 May 2018, 04:18 I posted it back on page one :rolling: no one read it.
:rolling:
weblord
Re: Navbar 3.2.x
Post by weblord »
This is exactly what I want . thank you very much.
	<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{{ lang('INCENTIVE WALL') }}</span>
</a>
my question is when installed from the start, it came out as Games, how do you change Games into something else?
Sniper_E wrote: 12 May 2018, 01:35
</a>
		</ul>
	</div>
</li>
</a>
		</ul>
	</div>
</li>
Re: Navbar 3.2.x
weblord wrote: 15 May 2018, 15:51 this is exactly what I want . thank you very much.
</a>
</a>
		</ul>
	</div>
</li>
</a>
		</ul>
	</div>
</li>
Look in the language common.php file.
I see that you changed L_NAVBAR_LINKS to lang('INCENTIVE WALL') so change that also in common.php file
Then you can change the language files from games to whaterver you like.
so common.php looks like:
	'INCENTIVE WALL'		=> 'Whatever wall',
Re: Navbar 3.2.x
dmzx wrote: 01 Mar 2016, 09:03 Change language file to whatever you want the call the navbar menu.
Look at the bottom of the dmzx/navbar/language/en/common.php
	'NAVBAR_LINKS'		=> 'Games',
You can change 'NAVBAR_LINKS' => 'Games', to 'NAVBAR_LINKS' => 'Extensions',
Or you can add other drop-down menu names for other drop-down menus on new lines.
	'EXTENSIONS_LINKS'      => 'Extensions',
And use the extra line you added in your template as...
<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{{ lang('EXTENSIONS_LINKS') }}</span>
weblord
Re: Navbar 3.2.x
Post by weblord »
Got it. nice thanks.
dmzx wrote: 15 May 2018, 16:37
</a>
</a>
		</ul>
	</div>
</li>
</a>
		</ul>
	</div>
</li>
boldherri
Re: Navbar 3.2.x
Post by boldherri »
Sniper_E wrote: 08 May 2018, 00:21 I see why your yahtzee icon is off. That game is using a icon image instead of a fa-icon.
			<li class="small-icon icon-knuffel"><a href="/knuffel" title="Yahtzee">Yahtzee</a></li>
You could select a fa-fa icon to use in that code and your icons will line up.
			<li data-last-responsive="true">
				<a href="/knuffel" title="Yahtzee" role="menuitem">
				<i class="icon fa fa-yahoo" aria-hidden="true"></i> <span>Yahtzee</span></a>
			</li>
As far as your links duplicated in the navbar...
Once you get them in your drop-down then remove the event template like I instructed above.
Hi guys,
I'm trying but i can not,
in this code how do you add a link that opens an external page?
				<a href="/knuffel" title="Radio Live" role="menuitem">
				<i class="icon fa fa-yahoo" aria-hidden="true"></i> <span>Radio Live</span></a>
			</li>
and can you delete the game button? I only need to put a button connected to an external link
EDIT:
I entered this code and the button appears,
	<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{{ lang('Radio Live') }}</span>
</a>
how do i add a link to the button?
EDIT:Ok i have solved,
the link was to be added instead of the hash sign #
here:
I'm sorry that nobody here in the forum gave me a simple advice
Re: Navbar 3.2.x
boldherri wrote: 31 May 2018, 22:52 I'm sorry that nobody here in the forum gave me a simple advice
You just posted this yesterday afternoon. And I am just now seeing your post here this morning.
No one is sitting online here waiting for your post to come in so they can give you an immediate response.
It's like you expected an instant response. There is no Live Help available on these sites waiting to help you.
Please go cry somewhere else about that. And no one is bound to give help that fast so please don't demand it.
