3.1.x Extensions Database 3.1 / 3.2Note Extension
Re: Note Extension
Our little altercations were for the title in the note. clight77 and I had a problem with the note title defaulting to our style's default color.
It would not pick up the color set in dmzx's note.css stylesheet.
.note-box {
    background-color: #ebebeb;
    border: 1px solid #bbb;
    border-radius: 6px;
    color: #333;
    font-size: 12px;
    margin-bottom: 10px;
    padding: 2px 6px;
    text-align: justify;
    width: auto;
    margin-right: 60px;
.note-box.blue {
    background-color: #94c4ff;
    border-color: #6b92bd;
    color: #115098;
.note-box.yellow {
    background-color: #fffa78;
    border-color: #FFE403;
    color: #333300;
.note-box.green {
    background-color: #a7ff93;
    border-color: #43a347;
    color: #043300;
.note-box.red {
    background-color: #ff9393;
    border-color: #a30004;
    color: #330002;
.note-box.black {
    background-color: #999999;
    border-color: #000000;
    color: #2D2D2D;
If we chose the green note selection, the text color would be (#043300) green but the tiltle would be black in mine... or white in clight77 style.
So we added a class in the note bbcode line:
<div class="note-box {INTTEXT1}"><strong class="note-title">{INTTEXT2}:</strong> {TEXT}</div>
And added the colors for the note titles in the note.css
.note-box {
    border-radius: 6px;
    color: #333;
    font-size: 12px;
    padding: 2px 6px;
    width: auto;
    margin-right: 60px;
.note-box.blue {
    color: #115098;
.note-box.blue .note-title {
    color: #053062;
.note-box.yellow {
    border-color: #C2AE02;
    color: #584F00;
.note-box.yellow .note-title {
    color: #494100;
.note-box.green {
    color: #043300;
.note-box.green .note-title {
    color: #021E00;
.note-box.red {
    color: #330002;
.note-box.red .note-title {
    color: #1D0001;
.note-box.black {
    color: #2D2D2D;
.note-box.black .note-title {
    color: #000000;
In this example the note title colors are set a little darker than the text colors. The title colors show correctly here in dmzx's style.
miri4ever
Re: Note Extension
Post by miri4ever »
I just asked because I saw This kind of thing inside you NOTE Tags inside normal posts. Mine just going all over the line until the end even if they are empty.
Note: test
Re: Note Extension
miri4ever wrote: 25 Jun 2017, 00:04I just asked because I saw This kind of thing inside you NOTE Tags inside normal posts. Mine just going all over the line until the end even if they are empty.
This was accomplished by changing the div to span in the note bbcode like the example I linked to.
miri4ever wrote: 24 Jun 2017, 17:23I also having an question if it could be modified for the new RIN Editor the Button with color selection is shown inside this editor. I have tried to reproduce the code from the Tables extension, because it shows without any problem. But it seems note extension is working a little bit differ to be called.
But this I'm not sure exactly what you are referring to. Maybe color square selections like the table selections? I could do that.
I did notice that the margin-bottom: 10px made the drop down selections spread apart after installing this. Is that what you see too?
miri4ever
Re: Note Extension
Post by miri4ever »
I have made a screenshot for you:
I'm using the new editor developed here:
https://www.phpbb.com/community/viewtop ... &t=2427126
The funny thing is your Table exentsion working so well with it, even if it's not designed to do. It display an own button for this exentsion inside RIN Editor. I do not understand how this kind of appear is done and what is special with TABLE and this MEDIA Extension to show their buttons. Ok they won't appear inisde ACP whatever it will cause. But they are here.
I now wanted to use this kind of work for others extension also being called this way. Don't know if it is template related only and how to do this for example for you NOTE Extension and many other more.
Number 2 should look like Number 1 inside this picture. What have you done special there to get it work with TABLES but not with NOTES ?
Re: Note Extension
I had to get rid of my version and installed a fresh copy but now there is no BBcode in ACP, any ideas?
THX
All I need is the BBCode usage stuff.
tamarin
Re: Note Extension
Post by tamarin »
dmzx wrote: 01 Aug 2016, 19:42
tamarin wrote: 13 Jul 2016, 15:19
TWEagle wrote: 28 Jan 2016, 10:50 this doesn't work in combination with the advanced BB-Code extension??
+1000
did you try to add the event?
- Hello.
Now I have added the event, but unfortunately nothing has changed.
Do you still have an idea?
networker007
    Mac OS X Safari
Re: Note Extension
Post by networker007 »
tamarin wrote: 14 Nov 2019, 18:27
+1000
- Hello.
On my phpBB it doesn't work i have put this file
(see here: viewtopic.php?f=49&t=1557&hilit=box)
in the folder /ext/dmzx/note/styles/all/template/event/
when I want to post ->white site (nothing in the apache error log). So I remove the above file. hope for an solution in the future. THX
Re: Note Extension
Updated to 1.0.1 and now there are no dropdown colors in forum or chat ?
Reverted back to 1.0.0 but still no colors pbpbb 3.3.3
Re: Note Extension
I just installed note ext 1.0.1 on my 3.3.3 board and it looks good to me.
HarveyWNvm LLC.
Re: Note Extension 3.3.x
Post by HarveyWNvm LLC. »
Hello! People have made a little change for anyone in need. version everything happens on the latest version of phpBB 3.3.x
dmzx/Note-Extension
Add class
phpBB Version: 3.3.x
php_version 7.1.3
Name: Note Extension
Note: Free download Link
nFL-Cs.InFo Clock to Banner
Re: Note Extension
This is the 3.1 section pls send your version to me or dmzx also i noticed yours was version 8.1.9 ? the version check will fail as its no where near version 8.x
jordon
Re: Note Extension
Post by jordon »
I installed the extension works on 3.3.x only the button does not appear in bbcode I use this extension
phpbb. com/customise/db/extension/advanced_bbcode_box/
HarveyWNvm LLC.
Re: Note Extension
martin wrote: 24 Dec 2021, 03:23 This is the 3.1 section pls send your version to me or dmzx also i noticed yours was version 8.1.9 ? the version check will fail as its no where near version 8.x
I have it and it works very well and I checked that it works on my site it works exactly
Re: Note Extension
It no longer works on 3.3.7. Too bad.
Re: Note Extension
I am on 3.3.7 and my version works :)
