Fatal error: Uncaught exception 'Twig_Error_Loader' with message 'Unable to find template "@dmzx_modxcommands/event/vse_abbc3_posting_editor_buttons_custom_tags_before.html" (looked into: ) in "@vse_abbc3/abbc3_posting_buttons.html" at line 204.' in /home/empathyw/public_html/the-wakeup-call.com/vendor/twig/twig/lib/Twig/Loader/Filesystem.php:215 Stack trace: #0 /home/empathyw/public_html/the-wakeup-call.com/phpbb/template/twig/loader.php(107): Twig_Loader_Filesystem->findTemplate('@dmzx_modxcomma...') #1 /home/empathyw/public_html/the-wakeup-call.com/vendor/twig/twig/lib/Twig/Loader/Filesystem.php(139): phpbb\template\twig\loader->findTemplate('@dmzx_modxcomma...') #2 /home/empathyw/public_html/the-wakeup-call.com/vendor/twig/twig/lib/Twig/Environment.php(312): Twig_Loader_Filesystem->getCacheKey('@dmzx_modxcomma...') #3 /home/empathyw/public_html/the-wakeup-call.com/vendor/twig/twig/lib/Twig/Environment.php(378): Twig_Environment->getTemplateClass('@dmzx_modxcomma...', NULL) #4 /home/empathyw/public_html/the-wakeup-call in /home/empathyw/public_html/the-wakeup-call.com/vendor/twig/twig/lib/Twig/Loader/Filesystem.php on line 215
This is the error code I get on Board Announcement add-on on (ext/phpbb/boardannouncement) admin panel. It seems to me that Userrname+Modxcommand are in conflict with Board Announcement.
Kar wrote: 09 Jun 2016, 07:33
One suggestion - could it be possible to color the user name in blue (for example) - as on your forum? Also the member to be notified that his name is mentioned (something like on ProBoards - a simple script) - I think I saw this add-on on phpbb, but for older version of phpbb.
This is not possible for now.
I install the Quick Reply add-on, uninstall it, and as result I get some Re: on subject line - what a nuisance. How can I repair it?
Hi Dmzx,
why it’s not possible ? Time question or it need phpBB 3.2 ?
Galixte de EzCom wrote: 29 Sep 2016, 16:23Could it be possible to color the user name in blue?
In the acp if the group color is blue it will post the username in blue.
Or do you want it to post all usernames in blue? There is a simple edit to make that happen.
Galixte de EzCom wrote: 29 Sep 2016, 16:23Also the member to be notified that his name is mentioned.
That would be an entirely different extension.
Is it possible to make this extension so that you can choose a username by wildcard?
That should be very interesting for very large boards (>5000 users).
For example: you can type dmz in the box (where now is set Select Username) and you only see the usernames beginning with dmz.
Then you only see for example:
dmz
dmzb
dmzk
and choose one of this 4 names
Edit: Something like you search a user in the memberlist
