3.1 & 3.2 Extensions Database 3.1 / 3.2phpBB Countdown
ninowebs
Re: PhpBB Countdown
Post by ninowebs »
Ok tnk , this my Link
here are active both extensions , but I only see the quotes do not see the Countdown if off shares miraculously reappears Countdown
Re: PhpBB Countdown
No i need to the link to the ext that is conflicting with the countdown ext.
ninowebs
Re: PhpBB Countdown
Post by ninowebs »
I'm sorry , I have not understood :???:
HeinrichP
Re: PhpBB Countdown
Post by HeinrichP »
Nice extention, thank you :thumbup:
TomS2
    Mac OS X Safari
Re: PhpBB Countdown
Post by TomS2 »
Very nice extension, thanks for this idea.
However ist it possible to have the countdown only shown to a certain user group (or at least to registered users)?
Thanks in advance
Regards
Tom.
Re: PhpBB Countdown
TomS2 wrote:Very nice extension, thanks for this idea.
Thanks in advance
Regards
Tom.
You can add registered group in this line:
countdown/overall_header_page_body_before.html at master · dmzx/countdown · GitHub
like this:
<!-- IF not S_IS_BOT and COUNTDOWN_ENABLE and S_REGISTERED_USER -->
nelflucifer
Re: PhpBB Countdown
Post by nelflucifer »
Hello everyone! As I promised, post the translation(s):
ru.zip
English Forums
sgtevmckay
Re: PhpBB Countdown
Post by sgtevmckay »
Any way to add additional countdown timers?
With the call of the release date of WoW Legion. I already have use for 3 and up to 5 coming.
Re: PhpBB Countdown
Unless the code hs changed it used to only work with one counter on a page only. (maybe wrong)
sgtevmckay
Re: PhpBB Countdown
martin wrote: 20 Apr 2016, 02:47 Unless the code hs changed it used to only work with one counter on a page only. (maybe wrong)
That is what I am seeing, but wanting to verify...
I am being so sleep deprived that I am running on Caffeine, Nicotine, Sugar, and Adrenaline....
So I am missing the world as I fly by.
Wanted to double verify that I did not miss something :oops:
Hopefully, I will be done with this Retrofit sometime tomorrow and be done with this contract (20 to 22 hour days suck!)
clight77 Online
Re: PhpBB Countdown
I have stokers xmas countdown installed but no text appears on the index page, just theinputted area shows.
So I disabled it and added just dmzx phpbb countdown, and it does the same thing.
What am I missing ?
Also it fecks up mchat, it always goes to the top of all the messages. And can't post in mchat either.
using phpbb 3.1.9
clight77 Online
Re: PhpBB Countdown
THX but that is all french to me... lol
Re: PhpBB Countdown
Let me know if you sorted it or not and il do it.
clight77 Online
Re: PhpBB Countdown
martin wrote: 19 Jun 2016, 10:58 Let me know if you sorted it or not and il do it.
Nope no luck, I removed the phpbb countdown also.
Feel free to fix it if you find time :)
It works fine on my test site tho :)
