3.3.x Extensions Database 3.2 / 3.3Custom index page
Re: Custom index page
Custom index page_1.0.0-Slovenian.zip
Alpha
Post by Alpha »
Salut dsl rien compris que faut-il changer exactement, car chez moi, je me retrouve avec ceci merci
Banned
Banned
Et tu cherches à faire quoi avec le fichier composer.json ?
Il faudrait que tu expliques ce que tu veux faire par ton premier message dans cette discussion.
Alpha
Post by Alpha »
ssl wrote: 15 Feb 2023, 17:05 Et tu cherches à faire quoi avec le fichier composer.json ?
slt quel faut-il changer à l'intérieur ??
Banned
Banned
Tu n'a rien à changer dans ce fichier propre à l'extension.
Si tu n'expliques pas plus ta question ne t'étonnes pas de ne pas avoir plus d'aide.
English pls.
Alpha
Post by Alpha »
Hi, well cool, I installed great, but how to put that in French "welcome no worries in French, I changed it" but "Not yet an account?" impossible to put in FR? If I put it, I can no longer link an idea, thank you.
Sorry for english.
Alpha wrote: 08 Apr 2023, 09:48 Hi, well cool, I installed great, but how to put that in French "welcome no worries in French, I changed it" but "Not yet an account?" impossible to put in FR? If I put it, I can no longer link an idea, thank you.
Sorry for english.
if im understand you right, you want to translate this in french language?
so create folder with name "fr" then open customindexpage_v100\customindexpage\language\en\customindexpage.php
and translate it to french
Alpha
Post by Alpha »
ivailo95 wrote: 08 Apr 2023, 12:23
Sorry for english.
Hello, I don't really understand the trick? Because when I put in FR, impossible to connect
Alpha
Post by Alpha »
Sorry for english.
It does not work, it blocks me the same connection for the user??
So you translated the lang file to French? Is your file customindexpage\language\fr\customindexpage.php
Alpha
Post by Alpha »
Sniper_E wrote: 09 Apr 2023, 10:50 So you translated the lang file to French? Is your file customindexpage\language\fr\customindexpage.php
Hello, I had done it, but it blocks my connection, just this sentence, any idea of ​​the problem?? THANK YOU.
This extension just add simple page, there is no logic to block your connection :wtf:
do you have other ext which can block connection?
Also you can translate what u showed (above ur post upthere)
as you go in ACP "extensions" tab , you will see language editor
/////////////////////////////------------------------------------------ Edit only below this line ---------------------------------/////////////////////////////
	'CUSTOMINDEXPAGE_WELCOME'			=> 'Добре дошли в',
	'CUSTOMINDEXPAGE_ACCOUNT'			=> 'Нямате акаунт?',
	'CUSTOMINDEXPAGE_COPYRIGHT'			=> 'Copyright',
	'CUSTOMINDEXPAGE_RIGHTS'					=> 'All rights reserved.',
/////////////////////////////------------------------------------------ Edit only above this line ---------------------------------/////////////////////////////
Alpha
Post by Alpha »
I tried everything, impossible to put. (You don't have an account yet?) in French this one, no problem, proof (Welcome to - Visions'Land) directly by ACP CSS, no extension is in conflict??
Alpha
Post by Alpha »
If someone has a French translation, I'm interested, thanks :)
