3.2.x Extensions Database 3.2 / 3.3Set forum width 3.2.x
mortalites
Re: Set forum width 3.2.x
Post by mortalites »
I guess I am confused then. Do i need to edit any files now that I set the global px size to 1400 for all users? Will this fix the issue withe the search bar and also how do I hid the "Width" Link?
Thanks,
Try this unistall your other and delete data there is no point playing with the mobile side of the ext as its shrinks to screen size this is 1400px min
dmzx_setforumwidth_1_0_1 (1).zip
mortalites
Thank you so much. That removed the Width Link from the Nav bar.
Only problem still is the Search bar.
Files updated to pass html5 also removed the extra ";" that was in it.
rommeltje
Post by rommeltje »
Does this still work in 3.3.x? If not, is there an update on the way, or is there an alternative?
Try it and let us know.
rommeltje
Post by rommeltje »
It works!
I have a newer version of this it uses % rather than px and a few other tweaks shall prob post it.
Set forum width_1.0.1-Slovenian.zip
Sylver Cheetah 53
Post by Sylver Cheetah 53 »
martin wrote: 4 years ago I have a newer version of this it uses % rather than px and a few other tweaks shall prob post it.
Can you please share it with the rest of us?
Free your mind!
No as i have now incorporated it in to a vip ext i have.
