Extensions Database 3.1 / 3.2 ⇒ 3.1.x Note Extension
3.1.x & 3.2.x
uruguayito
    Mac OS X iPad
Re: Note Extension
Post by uruguayito »
Any idea? :roll:
[ Post made via iPad ] Image
I'm a latin american man.
Spanish is my language.
1 given 1
Re: Note Extension
Unistall posting buttons it no longer works with latest mchat so it breaks bbcodes.
I have the buttons working on mine board wide but is a temp solution for now http://www.martins.homelinux.net/forum/ ... f=10&t=337
nelflucifer
    unknown unknown
Re: Note Extension
Post by nelflucifer »
And the expansion of "Note" as it can be combined with "Advanced BBCode Box" ? Include and no. have the Admin manually create a separate code....
English Forums
uruguayito
Re: Note Extension
martin wrote: 05 Mar 2016, 17:30 Unistall posting buttons it no longer works with latest mchat so it breaks bbcodes.
I understand, but I haven't got installed mchat .... :???:
I can't read your link: Information
You are not authorised to read this forum.
sgtevmckay
Re: Note Extension
Post by sgtevmckay »
TWEagle wrote: 28 Jan 2016, 10:50 this doesn't work in combination with the advanced BB-Code extension??
I just skimmed through all the posts.
Was the ability to use this with the ABBC3 Extension ever addressed, or is there a fix and I missed it ???
13 given 1
Re: Note Extension
sgtevmckay wrote: 29 Apr 2016, 01:03
You have to do same like here viewtopic.php?p=7946#p7946
tamarin
Re: Note Extension
Post by tamarin »
+1000
13 given 1
Re: Note Extension
tamarin wrote: 13 Jul 2016, 15:19
+1000
did you try to add the event?
tamarin
Re: Note Extension
Post by tamarin »
dmzx wrote: 01 Aug 2016, 19:42
+1000
No.
But I have the same problem.
miri4ever
Re: Note Extension
Post by miri4ever »
Extension not working at PHPBB 3.2. BBCodes not parsed. Will there be an update somehow ?
13 given 1
Re: Note Extension
miri4ever wrote: 22 Jan 2017, 17:04 Extension not working at PHPBB 3.2. BBCodes not parsed. Will there be an update somehow ?
Note: Is still working in 3.2 but special characters can be a problem
miri4ever
Re: Note Extension
Post by miri4ever »
It took me some time to get it work finally now. I knew it was fine at PHPBB 3.1 but it really need the : between outwise it's not working. I just put inside normal text without Notiz: Second Text. With just Text to test it was not working :whistl:
Re: Note Extension
Note: blue
Note: yellow
Note: green
Note: red
Note: black
playing with layout: http://www.sniper-e.is-slick.com/testin ... p=169#p169
miri4ever
Re: Note Extension
Post by miri4ever »
I have tested your modification at this link and used the second one. Changed BBCode and NOTE.CSS. But my Notes still getting over the complete line and not only the part with the text inside.
I also having an question if it could be modified for the new RIN Editor the Button with color selection is shown inside this editor. I have tried to reproduce the code from the Tables extension, because it shows without any problem. But it seems note extension is working a little bit differ to be called.
Re: Note Extension
Great that works a treat. :)
My colors:
