3.2 & 3.3 Extensions Database 3.2 / 3.3Ultimate Points Extension
seacoast
Re: Ultimate Points Extension
Post by seacoast »
That worked perfectly! Thank you. :)
One suggestion (and I know you have many for UP). On the Robbery page, perhaps when a member to be robbed is picked, you can show their points or the max. points available to be robbed. Just a thought. Thanks again!
lgmf
Post by lgmf »
ivailo95 wrote: 20 Oct 2018, 12:11 guys try this dmzx's extension i just test it and suspect no errors :thumbup:
Also gave error!
I installed version 1.2.2 and the one that you made available and both are giving error in the momentto that I click to activate the extension.
I was using a version that was working perfectly v1.1.6
dani50
Post by dani50 »
Hello! question, can an extension update be made instead of the message, "You need more Points in order to download this attachment!"
which is taken from phpbb, to display a page with point packages for purchase? in my case this page https://electronicforum.ro/app.php/shop
Thx
Dopply
Post by Dopply »
Are there any active shop mods for this extension? Something where you can redeem your points for items in a virtual inventory. Any help would be much appreciated. Thank you!
3 given 0
Dopply wrote: 07 Sep 2019, 22:42 Hello,
For now not. Maybe future it will be.
Midway
Post by Midway »
Hi I have this error when I want to rob a member
Fatal error: Uncaught Error: Call to a member function has() on null in /home/clients/04bba139eb5e41020ef875068f42a5f4/web/ext/dmzx/ultimatepoints/core/points_robbery.php:322 Stack trace: #0 /home/clients/04bba139eb5e41020ef875068f42a5f4/web/ext/dmzx/ultimatepoints/controller/main.php(259): dmzx\ultimatepoints\core\points_robbery->main(Array) #1 /home/clients/04bba139eb5e41020ef875068f42a5f4/web/vendor/symfony/http-kernel/HttpKernel.php(135): dmzx\ultimatepoints\controller\main->handle_ultimatepoints() #2 /home/clients/04bba139eb5e41020ef875068f42a5f4/web/vendor/symfony/http-kernel/HttpKernel.php(57): Symfony\Component\HttpKernel\HttpKernel->handleRaw(Object(phpbb\symfony_request), 1) #3 /home/clients/04bba139eb5e41020ef875068f42a5f4/web/app.php(35): Symfony\Component\HttpKernel\HttpKernel->handle(Object(phpbb\symfony_request)) #4 {main} thrown in /home/clients/04bba139eb5e41020ef875068f42a5f4/web/ext/dmzx/ultimatepoints/core/points_robbery.php on line 322
fastgil.com
    Windows XP Firefox
Post by fastgil.com »
https://github.com/phpBB-Studio/AdvancedShopSystem
it should be adapted to this extension, if it was already not already
I did not try
dmzx can you tell us if they are suitable to work together?
fastgil.com
    Windows XP Firefox
Unfortunately this huge extension, is not compatible with ultimate, what a huge disappointment
at work dmzx gogogogo :whistl: :rolling:
3 given 0
dani50
Post by dani50 »
Hi, how can I give all members a bonus of x points. I have almost 4000 members and it is difficult to do this manually.Thx
redragon
    Ubuntu Firefox
Post by redragon »
Hello, i there a way to use autogroups with ultimatepoints?
3 given 0
dani50 wrote: 09 Dec 2019, 14:18 Hi, how can I give all members a bonus of x points. I have almost 4000 members and it is difficult to do this manually.Thx
You can do in ACP settings see "Group Transfer" section to add the points to groups.
3 given 0
redragon wrote: 10 Dec 2019, 08:47 Hello, i there a way to use autogroups with ultimatepoints?
For now not.
redragon
    Ubuntu Firefox
Post by redragon »
Is it planned to had that?
3 given 0
redragon wrote: 10 Dec 2019, 09:19 is it planned to had that?
I need to check it but cannot give time indication, working on various other extension right now.
But will add it to the list "To Do" :wink:
