3.2 & 3.3 Extensions Database 3.1 / 3.2 ⇒ Mobile Device
wads24
Re: Mobile Device
I removed your extension and just tried adding it back but it won't enable or delete data. Getting a 405 error. Have you had any other people with same issue? I posted in topic but no reply.
Did you know registering is disabled on your site?
Re: Mobile Device
Is there any stable version or new version of this extension?
i ask cuz the last time i used it i saw errors in t for some phones.
Re: Mobile Device
Version 1.0.6 download on the first post in this topic is a stable version.
@wads24 I'm not sure what problem you are having by not being able to delete data after disabling the extension.
Martin or I would have to take a look for you if you can not get past that.
1. Disable mobile device extension and delete data and remove old files from your server.
2. Download the latest version from the first post, extract and copy to your server via ftp.
3. Enable mobile device extension in ACP. Halla at martin if you run across any problems.
Re: Mobile Device
there is errors in some phonesSniper_E wrote: 20 Dec 2018, 20:15 Version 1.0.6 download on the first post in this topic is a stable version.
3. Enable mobile device extension in ACP. Halla at martin if you run across any problems.![]()
like this when i viewtopic.php?f=10&t=3185
Re: Mobile Device
Just went to your site on mobile and the mobile device ext was not even on this time.
But I did enter your forum through my phone before and saw no problem.
Martin has connected there on his phone and saw no problems either.
You just may need to...
. . . Do it!Sniper_E wrote: 20 Dec 2018, 20:15 1. Disable mobile device extension and delete data and remove old files from your server.
wads24
Re: Mobile Device
Nope, still not able to enable...Sniper_E wrote: 20 Dec 2018, 20:15 Version 1.0.6 download on the first post in this topic is a stable version.
General Error
SQL ERROR [ mysqli ]
Lost connection to MySQL server during query [2013]
SQL
ALTER TABLE `phpbb_posts` ADD COLUMN `post_device_title` varchar(30) NULL
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 997
CALL: trigger_error()
LINE: 193
FILE: [ROOT]/phpbb/db/tools/tools.php
LINE: 1064
LINE: 1272
CALL: phpbb\db\tools\tools->_sql_run_sql()
LINE: 549
CALL: phpbb\db\tools\tools->sql_column_add()
CALL: phpbb\db\tools\tools->perform_schema_changes()
FILE: [ROOT]/phpbb/db/migrator.php
LINE: 714
CALL: call_user_func_array()
LINE: 661
CALL: phpbb\db\migrator->run_step()
LINE: 400
CALL: phpbb\db\migrator->process_data_step()
LINE: 288
CALL: phpbb\db\migrator->try_apply()
LINE: 241
CALL: phpbb\db\migrator->update_do()
FILE: [ROOT]/phpbb/extension/base.php
LINE: 78
CALL: phpbb\db\migrator->update()
FILE: [ROOT]/phpbb/extension/manager.php
LINE: 190
CALL: phpbb\extension\base->enable_step()
FILE: [ROOT]/ext/boardtools/upload/includes/functions/extensions.php
LINE: 294
CALL: phpbb\extension\manager->enable_step()
FILE: [ROOT]/ext/boardtools/upload/acp/upload_module.php
LINE: 181
CALL: boardtools\upload\includes\functions\extensions::enable()
LINE: 676
CALL: boardtools\upload\acp\upload_module->main()
FILE: [ROOT]/adm/index.php
LINE: 82
CALL: p_master->load_active()-
Re: Mobile Device
Can you look in phpmyadmin and see if the `post_device_title` column is still in the `phpbb_posts` table?
On delete data it is supose to delete that column from the posts table and the other columns from the users table.
Maybe it didn't delete that one and the new install is running into that. I really don't know...
In mobiledevice/migrations/mobiledevice_schema.php these are the columns added.
Look into those tables and make sure all of those columns are deleted and then install.
Why are you the only one having this problem??? Don't give up there has to be a reason.
If all of that fails try changing that line before installing.
'post_device_title' => array('VCHAR:30', ''),
'add_columns' => array(
$this->table_prefix . 'users' => array(
'mobile_browser' => array('UINT:1', 0),
'device_name' => array('VCHAR:30', null),
'user_mobile_welcome' => array('BOOL', 1),
'user_mobile_header' => array('BOOL', 1),
'user_mobile_self' => array('BOOL', 1),
$this->table_prefix . 'posts' => array(
'post_device_title' => array('VCHAR:30', null),
),Why are you the only one having this problem??? Don't give up there has to be a reason.
Re: Mobile Device
Is it installing ok ? looks like a left over module to me but i not been reading this topic.
Unistal the ext delete data then go into the system tab and look for any modules relating to mobile ext (dont know if i have an account or acp access on yours wads24 to check.
wads24
Re: Mobile Device
Can you look in phpmyadmin and see if the `post_device_title` column is still in the `phpbb_posts` table?Sniper_E wrote: 14 Jan 2019, 00:00 Can you look in phpmyadmin and see if the `post_device_title` column is still in the `phpbb_posts` table?
In mobiledevice/migrations/mobiledevice_schema.php these are the columns added.Look into those tables and make sure all of those columns are deleted and then install.Code: Select all
'add_columns' => array( $this->table_prefix . 'users' => array( 'mobile_browser' => array('UINT:1', 0), 'device_name' => array('VCHAR:30', null), 'user_mobile_welcome' => array('BOOL', 1), 'user_mobile_header' => array('BOOL', 1), 'user_mobile_self' => array('BOOL', 1), ), $this->table_prefix . 'posts' => array( 'post_device_title' => array('VCHAR:30', null), ), ),
Nope, I could not find post_device_title
Tried to delete data in ACP and got this error:martin wrote: 14 Jan 2019, 00:07 is it installing ok ? looks like a left over module to me but i not been reading this topic.
Fatal error: Maximum execution time of 30 seconds exceeded in /phpbb/request/request.php on line 285
No, I do not see any modules...
Changed max execution time now when I click delete data it takes to page it says requested page cannot be displayed...
adm/index.php?i=acp_extensions&sid=dac57bdaf46bd5dba1250ac48f6a3462&mode=main&action=delete_data&ext_name=sniper%2Fmobiledevic
Re: Mobile Device
Are you using the ext upload ext to upload and install exts ? if so version number and phpbb version pls
3.2.0 has issues on phpbb 3.2.5 so use 3.2.0-RC if your a 3.2.5 use. https://github.com/BoardTools/upload
Tarantino
Re: Mobile Device
The problem here is that he has a big posts table and his server has shorts timeouts. It will be impossible to install it.
Only way is to install it locally with xampp for example and then deploy it.
wads24
Re: Mobile Device
Yes, I am using phpbb 3.2.5 and Version:3.2.0-RC - I have also tried other way to manage extensions though.martin wrote: 15 Jan 2019, 09:41 Are you using the ext upload ext to upload and install exts ? if so version number and phpbb version pls
wads24
Re: Mobile Device
If so; why was I able to install the first time?Tarantino wrote: 15 Jan 2019, 20:01 The problem here is that he has a big posts table and his server has shorts timeouts. It will be impossible to install it.
wads24 wrote: 16 Jan 2019, 02:34Yes, I am using phpbb 3.2.5 and Version:3.2.0-RC - I have also tried other way to manage extensions though.martin wrote: 15 Jan 2019, 09:41 Are you using the ext upload ext to upload and install exts ? if so version number and phpbb version pls
Re: Mobile Device
You need someone to come over and look because I don't think you are trying the things suggested.
There has to be a reason why you are having this problem.
And this...
Did you not copy all of the error here? The e is missing from mobiledevice - It want find that.
Is that all you looked for in there? There were other suggestions for you to try.wads24 wrote: 15 Jan 2019, 03:16 Nope, I could not find post_device_title
And this...
wads24
Re: Mobile Device
That is the url it takes me to and forum page cannot be displayed. It's not from the error after I extended my Max execution timeSniper_E wrote: 16 Jan 2019, 03:48 You need someone to come over and look because I don't think you are trying the things suggested.Is that all you looked for in there? There were other suggestions for you to try.wads24 wrote: 15 Jan 2019, 03:16 Nope, I could not find post_device_title
And this...
