3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Ultimate Points Extension
Re: Ultimate Points Extension
Every extension on here is FOR PHPBB ONLY!
dathwerth
Hi, thank you for your extension.
I am having problem with the following actions:
Points to pay for new topic:
Enter here, how much points a user has to pay to start a new topic in this forum.
Points to pay for new post:
Enter here, how much points a user has to pay to make a new post in this forum.
I set the values to 10.00 and it still allow me to post it with 0 points.
Could you help me?
Could you help me?
Kami-sama
Add permission to the user/ group.dathwerth wrote: 24 Jun 2018, 18:09 Hi, thank you for your extension.
Could you help me?
Otherwise it does not work.
Problems problems i spent a week testing this ext with no issues
90% of the time you guys need to check settings also list other ext's you have installed.
Kami-sama
True that. Tho, points showing for guest posts is a real thingmartin wrote: 26 Jun 2018, 23:00 problems problems i spent a week testing this ext with no issues90% of the time you guys need to check settings also list other ext's you have installed.
Adjusting the topic event resolved that tho.
ramp
I working fixed the mod errors, If you have a error, report here https://github.com/rampmaster/ultimatepoints.
Will add the fix in next releaseramp wrote: 05 Jul 2018, 04:08 I working fixed the mod errors, If you have a error, report here https://github.com/rampmaster/ultimatepoints.
ramp
Ok, but. What is the official repository for send pull request?dmzx wrote: 05 Jul 2018, 09:52Will add the fix in next releaseramp wrote: 05 Jul 2018, 04:08 I working fixed the mod errors, If you have a error, report here https://github.com/rampmaster/ultimatepoints.
See https://github.com/dmzx/Ultimate-Points-Extension-3.2.xramp wrote: 06 Jul 2018, 00:41Ok, but. What is the official repository for send pull request?dmzx wrote: 05 Jul 2018, 09:52Will add the fix in next releaseramp wrote: 05 Jul 2018, 04:08 I working fixed the mod errors, If you have a error, report here https://github.com/rampmaster/ultimatepoints.
ramp
Thanksdmzx wrote: 06 Jul 2018, 09:37See https://github.com/dmzx/Ultimate-Points-Extension-3.2.xramp wrote: 06 Jul 2018, 00:41Ok, but. What is the official repository for send pull request?dmzx wrote: 05 Jul 2018, 09:52Will add the fix in next releaseramp wrote: 05 Jul 2018, 04:08 I working fixed the mod errors, If you have a error, report here https://github.com/rampmaster/ultimatepoints.
petejb
I have a problem where points aren't deducted for any activity, yet points are added fine.
I've checked user permissions and settings and they seem fine, am I missing something or is the code broken?
Points are not deducted for attachments, or if I set anything else to deduct.
AMadameSativa
+1 Same here, the extension works awesome, buy i need also translated into Spanish.Coryu wrote: 29 May 2018, 16:48 An extension that I was waiting for !! I will download and install. I'll see if it's
All errors are solved, installed on my test forum few weeks ago and see no problems.. Thank you :)
try to reset lottery history and user logs if there is errorsSolidjeuh wrote: 02 Aug 2018, 15:58 All errors are solved, installed on my test forum few weeks ago and see no problems.. Thank you :)
