3.2 & 3.3 Extensions Database 3.2 / 3.3Ultimate Points Extension
Re: Ultimate Points Extension
jan_2017 wrote: 03 Jun 2018, 19:55 Hello Martin...yes i saw that.
I'll rephrase it. If I enter 100% and the jackpot is 100 points then the user wins 100 points? At 50% the user wins only 50 points? Please excuse me, I find this probability in percent difficult to understand. :wall:
Bye Jan
No, then there is a 50/50 chance that there is a lotto winner.
If there is no winner, all the money will be in the next draw ..
Ok all right. Thanks. :mml:
NAPWR
Post by NAPWR »
Hello All,
is there a way for the ACP panel,
to join a User to the Bank :question:
At the moment, Users have to join the Bank themselves,
and those that don't lose their points to robbers.
Our new members don't know much yet,
but would like the Bank to be auto-join or something.
Thanks in advance. :mml:
My name is Dave I, and all things are out there, and we are in here :mml:
Rob me i'l just give my self another huge amount lol
gamestnforum
Post by gamestnforum »
Does anyone know if, or are, there any plans to introduce a collectable system or something to spend the points on? I know there is an option to pay for threads etc but outside of that, something to go into the profile that is automated, like little square icons etc.
A lot of my users are getting lots of points with nothing to spend on other than the lottery ahaha
Wrong Post
When i try to reset user logs
this issue appear to me
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1 [1064]
SQL
TRUNCATE TABLE
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 996
CALL: trigger_error()
LINE: 193
LINE: 329
FILE: [ROOT]/ext/dmzx/ultimatepoints/controller/admin_controller.php
LINE: 643
CALL: phpbb\db\driver\factory->sql_query()
FILE: [ROOT]/ext/dmzx/ultimatepoints/acp/acp_ultimatepoints_module.php
LINE: 43
CALL: dmzx\ultimatepoints\controller\admin_controller->display_lottery()
LINE: 676
CALL: dmzx\ultimatepoints\acp\acp_ultimatepoints_module->main()
FILE: [ROOT]/adm/index.php
LINE: 82
CALL: p_master->load_active()
This appear to me when try to reset lottery history
SQL ERROR [ mysqli ]
SQL
TRUNCATE TABLE
BACKTRACE
CALL: msg_handler()
LINE: 996
LINE: 193
LINE: 329
LINE: 643
LINE: 43
LINE: 676
LINE: 82
dmzx martin
How can i fix it? :eyes2: :roll:
Kakagawa
Post by Kakagawa »
dmzx wrote: 19 May 2018, 08:09 Will update soon some fixes.
Out now for the weekend.
Whats'up dmzx? What about shop for points? :smile:
mati4458
Post by mati4458 »
"Points to pay for new post:
Enter here, how much points a user has to pay to make a new post in this forum."
This function is not working at all. Tryed it many times and does not take any points from user after posting. Dmzx please fix it.
Yea dmzx need to fix much things in this ext.
ivailo95 wrote: 15 Jun 2018, 18:18 Yea dmzx need to fix much things in this ext.
Yes but all in time.
Kami-sama
Post by Kami-sama »
Anyone else had issue with points showing up next to guest posts?
weblord
Post by weblord »
Can anyone guide me on how to install ultimate points extension on php-fusion? since it has forums too similar to phpbb. someone please. thanks in advance.
weblord wrote: 23 Jun 2018, 16:45 can anyone guide me on how to install ultimate points extension on php-fusion? since it has forums too similar to phpbb. someone please. thanks in advance.
You can't. This extension is only for phpBB
