3.1.x Extensions Database 3.1 / 3.2Ultimate Points Extension
RTI kartname
Re: Ultimate Points Extension
Post by RTI kartname »
Guys no one who can tell me how to upgrade without losing the points accumulated and if there is no translation in Italian?
RTI kartname wrote: 17 Dec 2016, 14:06 Guys no one who can tell me how to upgrade without losing the points accumulated and if there is no translation in Italian?
Disable in ACP the extension Don't delete data!
Then upload new files to directory and enable again in ACP and clear cache.
RTI kartname
I had to completely erase the points of all users, a disaster, to make matters worse after I installed the new version this is what I get: :cry: :cry:
RTI kartname wrote: 17 Dec 2016, 16:26 I had to completely erase the points of all users, a disaster, to make matters worse after I installed the new version this is what I get: :cry: :cry:
www.phpbb.com Is down so thats why
RTI kartname
I do not understand, the site is unreachable
RTI kartname wrote: 17 Dec 2016, 18:12 I do not understand, the site is unreachable
Yes that is the problem.
RTI kartname
So the extension does not work for this design? if so why the older version (1.1.5)instead worked great?
RTI kartname wrote: 17 Dec 2016, 18:22 So the extension does not work for this design? if so why the older version (1.1.5)instead worked great?
I just installed on 2 test boards and works fine 1.1.6 version.
What version of phpbb are you using?
RTI kartname
3.1.10
3.1.10 is the most bad version I have seen in years :whistl:
Most of extensions seem to make problems because the code has changed inside phpBB (migrations e.g.)
Kevicar
Post by Kevicar »
Scanialady wrote: 26 Oct 2016, 17:03
Kinsman wrote: 25 Oct 2016, 22:01 Interesting, I can see at least three extensions updated their migration files to avoid the issue, so unsure of the way forward now beyone waiting for 3.1.11 to fix it.
I am waiting for fixes, too. No need to update to this buggy phpBB 3.1.10 version. Too much important parts with bugs.
I'm also waiting for these correction ! :???:
I can not successfully reinstall "Ultimate Points Extension" or other extensions, "Youtube Videos Gallery" on PhpBB 3.1.10.
If you have a solution, I'll take it !
:wink:
pikkio
Post by pikkio »
I followed all the steps for install the ext for the ultimate points, i just enabled the extension but when i click to the button extension in the ACP come this error:
Fatal error: Uncaught exception 'RuntimeException' with message 'Failed to obtain latest version information.' in /membri/bet777/phpbb/version_helper.php:295 Stack trace: #0 /membri/bet777/phpbb/version_helper.php(234): phpbb\version_helper->get_versions(true, false) #1 /membri/bet777/phpbb/version_helper.php(213): phpbb\version_helper->get_versions_matching_stability(true, false) #2 /membri/bet777/ext/dmzx/ultimatepoints/includes/version_check.php(67): phpbb\version_helper->get_suggested_updates(true) #3 /membri/bet777/ext/dmzx/ultimatepoints/controller/admin_controller.php(531): dmzx\ultimatepoints\includes\version_check->check() #4 /membri/bet777/ext/dmzx/ultimatepoints/acp/acp_ultimatepoints_module.php(41): dmzx\ultimatepoints\controller\admin_controller->display_points() #5 /membri/bet777/includes/functions_module.php(674): dmzx\ultimatepoints\acp\acp_ultimatepoints_module->main('\dmzx\ultimatep...', 'points') #6 /membri/bet777/adm/index.php(81): p_master->load_active() #7 {main} thrown in /membri/bet777/phpbb/version_helper.php on line 295
Can someone help me to resolve this issue?
thanks!
RTI kartname
The same error that I have, from what I understand this version is not compatible with phpBB 3.1.10, but I ask you: Why do not specify it in the first post of this incompatibility ??
silberfuchs
    Mac OS X Safari
Post by silberfuchs »
I just tried to update again from 1.1.5 to 1.1.6 after my board is updated to 3.1.10. Now I get the following error message. Sorry for the German message - I tried to translate as good as I could....
"Während der Anpassung der Datenbank ist etwas falsch gelaufen und ein Fehler aufgetreten. Die Änderungen, die vor dem Fehler durchgeführt wurden, wurden so weit wie möglich rückgängig gemacht. Du solltest jedoch prüfen, ob dein Board fehlerfrei funktioniert.
Ein Modul existiert bereits:"
"During the configuration of the database an error happened, so the changes where switched back. Please try if the board runs still okay. One modul already exists..."
silberfuchs wrote: 27 Dec 2016, 11:56 after my board is updated to 3.1.10. Now I get the following error
and there you have your problem :-D
You should really read the phpBB forum before you update. Everywhere where you go the people report errors with 3.1.10 since weeks. You should avoid this buggy update and stay with 3.1.9 instead. Or you have to try all the unverified fixes from bug tracker manually.
If you are able to reset back to 3.1.9 ... I would do.
For the German: a list of bugs of 3.1.10 (not complete, only some important ones...)
