3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Email List
romaamor
- Donator
Re: Email List
Easier to alter the extension than to explain.
uruguayito
- Donator
Re: Email List
Very usefull ....
thanks
ask: Do you plan to include the option to export the emails for groups?
thanks
Sorry for my bad English.
I'm a latin american man.
Spanish is my language.
zendiver
Re: Email List
Nice extension and very clean, thank you.
Quick question if I may: All of the other icons in my nav are text free, is it OK to remove the "Email List" portion of the link so just the icon and the rollover title remains?
I wanted to ask before altering. Again, thanks for the ext.
Re: Email List
zendiver wrote:Nice extension and very clean, thank you.
Open: ext/dmzx/emaillist/styles/prosilver/template/event/overall_header_navigation_append.html
<!-- IF S_EMAIL_LIST --><li class="small-icon icon-members"><a href="{U_EMAIL_LIST}" title="{L_EMAIL_LIST}" role="menuitem">{L_EMAIL_LIST}</a></li><!-- ENDIF -->Replace with Replace the preceding lines with the following
<!-- IF S_EMAIL_LIST --><li class="small-icon icon-members"><a href="{U_EMAIL_LIST}" title="{L_EMAIL_LIST}" role="menuitem"></a></li><!-- ENDIF -->-
uruguayito
- Donator
Re: Email List
uruguayito wrote: 12 Aug 2015, 18:55 Very usefull ....
thanks
Re: Email List
Need to check on this.uruguayito wrote: 19 Aug 2016, 16:33uruguayito wrote: 12 Aug 2015, 18:55 Very usefull ....
thanks
testingground
Re: Email List
How do I give my global mod access to this aswell as me (founder)?
Re: Email List
Remove the user id code and change to group code maybe some thing like this ? i have not tested.
// Founders Mods only access
if ($user->data['group_id'] == '5' || $user->data['group_id'] == '4')
trigger_error('NOT_AUTHORISED');
testingground
Re: Email List
Ive just tried that and for some reason it is ignoring the change and still only allowing founder access
Yes I have cleared cache etc
Re: Email List
Also there is this in the listener line 73.
change it to groups as well.
if ($this->user->data['user_type'] != USER_FOUNDER)change it to groups as well.
testingground
Re: Email List
I assume you mean this:
What do I change it too?
// Founders only access
return;
// add lang file
$this->user->add_lang_ext('dmzx/emaillist', 'common');
'U_EMAIL_LIST' => $this->controller_helper->route('dmzx_emaillist_controller'),
'S_EMAIL_LIST' => ($this->user->data['user_type'] == USER_FOUNDER) ? true : false,
humpty
Re: Email List
When logged on as the founder I see the button near top left. So far so good! It takes me to https://forum.xxxxxx.com/app.php/emaillist, but that page is blank. So I can't see the email list. Board version 3.1.9.
Re: Email List
Can you set redirect in ACP to on to check.humpty wrote: 06 Sep 2016, 19:42 When logged on as the founder I see the button near top left. So far so good! It takes me to https://forum.xxxxxx.com/app.php/emaillist, but that page is blank. So I can't see the email list. Board version 3.1.9.
humpty
Re: Email List
Where can I find the redirect in the ACP? (Am not yet familiar with all of phpbb yet!)
