3.2 & 3.3 Extensions Database 3.2 / 3.3Ultimate Blog
Re: Ultimate Blog
seacoast wrote: 5 years ago but still the ABBC3 editor is not there
Yes see that also, will check it when other items are done.
seacoast
Re: Ultimate Blog
Post by seacoast »
Great thanks!
Klammer
Re: Ultimate Blog
Post by Klammer »
Hello.
I was able to install it and it also shows up in acp. I cannot call it up in the forum. The link then leads to the following error.
Why is that ? Can it be due to the prefix of my database ?
My prefix is ​​not phpbb but pjkf.
What do I have to change to make it work ?
Thanks and regards
Klammer
phpBB 3.3.0
PHP 7.3
Allgemeiner Fehler
SQL ERROR [ mysqli ]
Expression #1 of ORDER BY clause is not in GROUP BY clause and contains nonaggregated column 'db_403529_2.c.comment_time' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by [1055]
SQL
SELECT b.blog_id, b.blog_title, b.blog_approved, b.blog_reported, b.blog_image, u.user_id, u.username, u.user_colour, GROUP_CONCAT(distinct bc.category_id) as categories FROM (pjkF_ub_blogs b CROSS JOIN pjkF_users u CROSS JOIN pjkF_ub_comments c) LEFT JOIN pjkF_ub_blog_category bc ON (b.blog_id = bc.blog_id) LEFT JOIN pjkF_zebra z ON (b.author_id = z.user_id AND z.friend = 1) WHERE b.author_id = u.user_id AND c.blog_id = b.blog_id GROUP BY b.blog_id ORDER BY c.comment_time DESC, b.blog_date DESC LIMIT 3
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 1023
CALL: trigger_error()
LINE: 195
FILE: [ROOT]/phpbb/db/driver/mysql_base.php
LINE: 45
LINE: 296
CALL: phpbb\db\driver\mysql_base->_sql_query_limit()
LINE: 337
CALL: phpbb\db\driver\driver->sql_query_limit()
FILE: [ROOT]/ext/mrgoldy/ultimateblog/core/functions.php
LINE: 407
CALL: phpbb\db\driver\factory->sql_query_limit()
FILE: [ROOT]/ext/mrgoldy/ultimateblog/controller/bloglist.php
LINE: 163
CALL: mrgoldy\ultimateblog\core\functions->blog_index_list()
FILE: [ROOT]/vendor/symfony/http-kernel/HttpKernel.php
LINE: 151
CALL: mrgoldy\ultimateblog\controller\bloglist->index()
LINE: 68
CALL: Symfony\Component\HttpKernel\HttpKernel->handleRaw()
FILE: [ROOT]/app.php
LINE: 35
CALL: Symfony\Component\HttpKernel\HttpKernel->handle()
Sorry for the bad english. I work with google translator
seacoast
Re: Ultimate Blog
Post by seacoast »
seacoast wrote: 5 years ago I disabled UB, deleted data and enabled UB. The error went away. Not sure what happened there, but still the ABBC3 editor is not there.
Just wanted to add that ABBC3 does work with UB on 3.2.1 but not 3.3
Austeyr
Re: Ultimate Blog
Post by Austeyr »
Not sure I'm doing something wrong but I've added this and it doesn't show for me to enable.
I've renamed the folder and moved it to dmxz folder still nothing.
Anyone else having this issue I got so many Extensions installed running the latest version of phpBB cheers in advance.
My phpBB Forums Top Ad Coop & Gamer Raid
I Run Several Advertising Websites. Find Out More & Get Advertising For Your Forum for FREE Share My Ads
TrekRed
Re: Ultimate Blog
Post by TrekRed »
A person creates a blog in a category. How do you create multiple topics on a blog? And there is no subscription button!
TrekRed
Re: Ultimate Blog
Post by TrekRed »
It turns out that a person in 1 blog can create only 1 topic? Must be divided into several topics!
TrekRed
Re: Ultimate Blog
Post by TrekRed »
Can you explain how to subscribe to a blog and add multiple topics in 1 blogs? All rights are exposed!
TrekRed
Re: Ultimate Blog
Post by TrekRed »
How can I get an alert after every post on any blog?
TrekRed
Re: Ultimate Blog
Post by TrekRed »
Tell me how to get notified about new blog posts and new blogs created? :question: :question: :question:
Austeyr
Re: Ultimate Blog
Post by Austeyr »
Don't know if you mentioned this above, but ive been trying to install this for over a week, adding the unzipped ext to ext/dmzx. turns out it needs to be added to ext/mrgoldy and then finally gave me the option to enable.
just a heads up if it's not working try adding a folder in ext title mrgoldy
stand corrected now the page app.php/ultimateblog says:
Information
The requested page could not be found.
lost now thought i had it.
Edit: Ok now I have something. The same directory as above but had to disable the reenable now is working from what I can see.
Update: Everything works flawlessly now,
deninho32
Re: Ultimate Blog
Post by deninho32 »
Thanks for sharing this extension, it works really well on phpBB 3.3.2. I still have some small issues though. When I post a blog the view count is incorrect. In the blog itself it shows the correct number of views, but through the notifications it is way off. After 30 minutes or so I get notifications with 30,000 views. I think that's a bit optimistic :D
Also, is this extension done or still in development? It would be nice to be able to select a "main article" that has a prominent position on the frontpage.
deninho32
Re: Ultimate Blog
Post by deninho32 »
Little bump here :D
I get notifications that say that one my articles has been read 1800 times, but when I check Google Analytics I find out that the page has only been viewed around 500 times. Is there something wrong in the counting process?
TrekRed
Re: Ultimate Blog
Post by TrekRed »
Make an alert for every new topic and message! Is it really that hard?
You have to constantly manually check all messages!
deninho32
    Android Opera
Re: Ultimate Blog
Post by deninho32 »
TrekRed wrote: 5 years ago Make an alert for every new topic and message! Is it really that hard?
Was this meant for me? Because I really don't know what you mean with this post. This is not about topics, but about how many times a blog is read. The numbers don't match and I try to find out what the problem is.
