3.2 & 3.3 Extensions Database 3.2 / 3.3Editor extension
olalavui
Re: Editor extension
Post by olalavui »
After install ext, i cannot know where is use for it ext?
Come back phpBB with phpBBVietnam :tumbsyes:
You dont use it install and enable thats it the ext dont show you any thing its more of a key for other ext's.
olalavui wrote: 03 May 2019, 08:08 After install ext, i cannot know where is use for it ext?
Why installing extensions if you don't know why they are for? :rolling:
HarveyWNvm
Post by HarveyWNvm »
Demo???
HarveyWNvm wrote: 16 Dec 2019, 10:18Demo???
There is no demo:
Adds editor extension to your forum, some extensions need this editor to work properly.
Just install and leave it on, no settings in acp needed.
HarveyWNvm
I just want to know what's in it?
HarveyWNvm wrote: 17 Dec 2019, 14:40 I just want to know what's in it?
With this extension several options can be added to core or other extensions.
Some of mine extensions require this extension to be installed.
HarveyWNvm
Already understood thanks!
Pls dont post in this topic it's not for cssmagic.
Topic cleaned up.
HarveyWNvm
Well!
Exabot
    Mac OS X Firefox
Post by Exabot »
Estonian translation.
et.zip
pboulanger
Post by pboulanger »
Pleased find the french translation
friendly,
Pierre
wads24
Post by wads24 »
Is this extension available on PHPbb extension site?
If PHPbb will not pass because editing off core files. Are you no longer going to have your extensions available on PHPbb.com?
wads24 wrote: 11 Jul 2020, 06:37 Is this extension available on PHPbb extension site?
No, some extensions are only available on this forum.
The editor is made for some code changes if needed in core or other extension that the author won't update.
So if needed this extension is implemented into the code.
