3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Milestones
Re: Milestones
Nvm, I changed index_body_block_stats_append.html into index_body_stat_blocks_after.html
That seems to work.
That seems to work.
Re: Milestones
Solidjeuh wrote: 15 Feb 2018, 16:34 Nvm, I changed index_body_block_stats_append.html into index_body_stat_blocks_after.html
That seems to work.
moby2006
Re: Milestones
Does this also work under phpbb 3.3.0?
Thank you
Thank you
moby2006
Re: Milestones
Hello dmzx,
I see the h3 at the end of the page
my repository setting is correct because the link in h3 leads right there.
When I click to watch or hide, I see nothing.
Can you install it without hide / view?
Re: Milestones
Can you PM me test account to check.moby2006 wrote: 23 Jan 2020, 16:58 When I click to watch or hide, I see nothing.
Re: Milestones
Hmmm was your 3.3 and update ? if so you got rogue code i just installed this on 3.3 for the 2nd time and no stray H3
On another note the download contains 2 of these and a stray <p> replace the with a
<script type="text/javascript">Code: Select all
<script>
- Banned
Re: Milestones
I just installed this extension on my forum and translated it into French.
There is no distinction between the singular and the plural
In French it is 106 fermés 26 ouverts
Possible to modify this in a future version?
umi
Re: Milestones
Just add fermés and ouverts into translated archives...ssl wrote: 27 Dec 2020, 23:37 Hi
- Banned
Re: Milestones
And so each time there will be 1 I modify the file to remove the S?
umi
Re: Milestones
Share here language directory please (en) and link to your foum
Re: Milestones
Make the corrections to the French lang file and attach it in here for a revised version of French lang. Just a thought...
- Banned
Re: Milestones
Hi Sniper
Here is the french translation pack
In the ACP
On the forum index
In the ACP
On the forum index
umi
Re: Milestones
Needs add two lines of code. One for singular and other for plural.
Ask for dmzx
Ask for dmzx
