i make so you wright, but i dont see in acp for activate....
3.2.x Extensions Database 3.2 / 3.3 ⇒ Welcome on index
DaSchorse
Re: Welcome on index
Version 3.2.2
DaSchorse
Ahh okay
i wait that Martin see this Topic and can give help.... xD
haha xD im forum worm xDDDDDDDDD
sometime it happen to wait motnt before the autothor or people see the topic xD so..xD
Jester
as Martin posted this is an update to stokers welcome in index mod , if you have that extension installed , just overwrite the files from this post download.martin wrote: 21 Apr 2016, 21:32 If you installed this ext your need to download it again and just install over the one you have stoker left some other ext code in it i have removed it now.
if not make the extension like this
ext / stoker / welcomeonindex
thanksJester wrote: 10 Feb 2018, 05:03as Martin posted this is an update to stokers welcome in index mod , if you have that extension installed , just overwrite the files from this post download.martin wrote: 21 Apr 2016, 21:32 If you installed this ext your need to download it again and just install over the one you have stoker left some other ext code in it i have removed it now.
DaSchorse
verry thanks, it runs^^ivailo95 wrote: 10 Feb 2018, 14:40thanksJester wrote: 10 Feb 2018, 05:03as Martin posted this is an update to stokers welcome in index mod , if you have that extension installed , just overwrite the files from this post download.martin wrote: 21 Apr 2016, 21:32 If you installed this ext your need to download it again and just install over the one you have stoker left some other ext code in it i have removed it now.
Aalodda
In STK i get this error how can i fix
[phpBB Debug] PHP Notice: in file [ROOT]/ext/stoker/welcomeonindex/event/listener.php on line 162: A non well formed numeric value encountered-
Aalodda
Ok solved. 😉alodda wrote: 28 Feb 2018, 22:31 Hi
In STK i get this error how can i fix![]()
[phpBB Debug] PHP Notice: in file [ROOT]/ext/stoker/welcomeonindex/event/listener.php on line 162: A non well formed numeric value encountered![]()
In: ext/stoker/welcomeonindex/event/listener.php
$member_length = $member_length - ($months * 2628000);Replace with Replace the preceding lines with the following
$member_length = $member_length - ((float)$months * 2628000);-
Argm3
Hello everyone is especially Martin
I install this extension successfully and it works very well on my site
but there is a small problem that I have not found a solution
please help
I want to display the text add + the statistics in the index of my forum
is there a solution
greeting
please help
is there a solution
greeting
Just installed it on mine and it works perfect check the text your adding.
