3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Username Colour Changer
miri4ever
Re: Username Colour Changer
Now you know :)
Some Problems if ADMIN Color and USER Color at the same time is active so I had to remove one. ADMINs shown both, but just one colorpicker and both could only select somehow the same color.
Funny
- New user
In my test forum, this works without problems
Have css username and username color activated.
See the result
mg Funny
See the result
mg Funny
eunaumtenhoid
* Brazilian Portuguese translation by eunaumtenhoid (c) 2018 [ver 1.0.2]
https://github.com/phpBBTraducoes/usernamecolourchanger
Warnergon
Username Colour Changer 3 2 x
I like the blue the best. You should add a background changer to display RM Maps...perhaps even have contents to get your map selected as an option.
Mellenei
- New user
Hello, ich have a fresh install of phpbb3.3 and now i want to install this Extension, but always when i activate them, i get the following error.. (sorry for my english)
The file "/homepages/35/d641270526/htdocs/ext/dmzx/usernamecolourchanger/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @request").
#0 /homepages/35/d641270526/htdocs/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/homepages/35/d...')
#1 /homepages/35/d641270526/htdocs/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /homepages/35/d641270526/htdocs/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /homepages/35/d641270526/htdocs/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /homepages/35/d641270526/htdocs/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /homepages/35/d641270526/htdocs/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /homepages/35/d641270526/htdocs/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /homepages/35/d641270526/htdocs/phpbb/di/container_builder.php(203): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /homepages/35/d641270526/htdocs/common.php(115): phpbb\di\container_builder->get_container()
#9 /homepages/35/d641270526/htdocs/adm/index.php(23): require('/homepages/35/d...')
#10 {main}
waltons73
When i enable the color changer extention on my PHPBB 3.3,2 version
i get this red error messages
any help on get this fix for the phpb 3.2.3
phpBB encountered an error building the container due to an installed extension. For this reason, all extensions have been temporarily disabled. Please try purging your forum cache. All extensions will automatically be re-enabled once the container error is resolved. If this error continues, please visit phpBB.com for support.
Exception: The file "/home5/rampart/public_html/retrovintage/ext/dmzx/usernamecolourchanger/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @request").
#0 /home5/rampart/public_html/retrovintage/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home5/rampart/...')
#1 /home5/rampart/public_html/retrovintage/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home5/rampart/public_html/retrovintage/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home5/rampart/public_html/retrovintage/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home5/rampart/public_html/retrovintage/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home5/rampart/public_html/retrovintage/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home5/rampart/public_html/retrovintage/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home5/rampart/public_html/retrovintage/phpbb/di/container_builder.php(212): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home5/rampart/public_html/retrovintage/common.php(115): phpbb\di\container_builder->get_container()
#9 /home5/rampart/public_html/retrovintage/adm/index.php(23): require('/home5/rampart/...')
#10 {main}
Exception: The file "/home/awesomeb/public_html/ext/dmzx/usernamecolourchanger/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @request").
#0 /home/awesomeb/public_html/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/awesomeb/...')
#1 /home/awesomeb/public_html/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/awesomeb/public_html/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/awesomeb/public_html/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/awesomeb/public_html/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/awesomeb/public_html/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/awesomeb/public_html/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/awesomeb/public_html/phpbb/di/container_builder.php(223): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/awesomeb/public_html/common.php(115): phpbb\di\container_builder->get_container()
#9 /home/awesomeb/public_html/adm/index.php(23): require('/home/awesomeb/...')
#10 {main}You do not have the required permissions to view the files attached to this post! Maybe your post count is too low.
Bruce Banner
Hi. I'm having a slight problem to do with this and another extension by somebody else,
Tried posting the url to the extension here but wasn't allowed. Just look up Colored Post Header on phpBB's main site.
The problem is that when I change the colour of my username, headers on my posts change colour too. I'd rather post headers just stay the same colour that's assigned to my group. As it says in that extension's description,
"allows you to have a colored message header according to the color assigned to the different groups of members."
So is there any way to work around this so that I can change the colour of my username without also changing the colours of post headers?
Thanks.
Thanks.
The clue is in the name on the ext on .com "username, headers" it takes the users colour.
So your trying to mix 2 user colour name exts it wont work unless that author changes it to group colour headers.
miri4ever
As the ADMIN Color Changer no longer changed my color inside the forum view with usernames. I need coming back to this and for now its doing this job perfect.
