3.1.x Extensions DatabaseNote Extension
Note Extension
Extension Name: Note Extension
This extension will add a note bbCode selection box in posting template.
Add class
Note Extension v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `note`.
  4. Copy the `note` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/note/composer.json
  6. Look for `Note Extension` under the Disabled Extensions list, and click its `Enable` link.
This topic has 63 replies
