3.3.x Extensions Database 3.2 / 3.3Download System
TWEagle
Re: Download System
Post by TWEagle »
dmzx wrote:It needs to make also then the category in the extension to show, like you do normal when you add it manual in ACP.
If I first make every cat then that is solved right??
Re: Download System
When you add the download in ACP it will also add it in the db tables, that will show the link in de download extension.
So adding a file in a category will not display, you need to alter the db also.
TWEagle
Re: Download System
Post by TWEagle »
Can I put my moderators to allow them to add downloads in the system +
Is it also possible to add one particular user at the download user (for the forum)?
nelflucifer
Re: Download System
Post by nelflucifer »
An interesting extension. There is a solution similar Attachments (extended version) let's See how will work together and individually. From guests to hide can?!
English Forums
Re: Download System
nelflucifer wrote: 03 Jan 2016, 13:59 An interesting extension. There is a solution similar Attachments (extended version) let's See how will work together and individually. From guests to hide can?!
Yes check the permissions for the groups
nelflucifer
Re: Download System
Thank you! :cool:
asouza
Re: Download System
Post by asouza »
HI guys
I'm sending the "common.php" translated for portuguese brazilian
portuguese-brazilian_common.zip
Re: Download System
asouza wrote: 15 Jan 2016, 14:13 HI guys
nelflucifer
Re: Download System
Hello everyone! As I promised, post the translation(s):
ru.zip
and the most difficult thing here was to translate the FAQ! Longer than all the others translated! :???:
killfrenzy
Re: Download System
Post by killfrenzy »
When I tried to new download it's show this error "The file does not exists in the named category. Since you selected the FTP upload method, this file needs to be uploaded via FTP in the correct directory BEFORE you can add it!". How can I fix it sir? thanks
Visit my blog http://androidcribs.com Androidcribs.comAndroidcribs Image
Re: Download System
killfrenzy wrote: 10 Feb 2016, 10:48 when I tried to new download it's show this error "The file does not exists in the named category. Since you selected the FTP upload method, this file needs to be uploaded via FTP in the correct directory BEFORE you can add it!". How can I fix it sir? thanks
Did you do this:
You can add a new upload via FTP or directly. If you are going to use the FTP upload method, the file needs to be uploaded to the correct category before you enter it here! You only can use on or the other method at a time!
Re: Download System
I never use ftp why not just upload like this so much faster.
killfrenzy
Re: Download System
Wow. Thanks for your help..problem solved!. :thumbup:
Re: Download System
How did you solve it what method did you go with ftp or direct upload others might have run into the same problem as you and this could be the answer there also looking for.
Anuj Dhawan
Re: Download System
Post by Anuj Dhawan »
I'd assume "download-system" will pick up the allowed extensions from the boards' list of "Manage attachment extensions". There I've "cob" extension allowed for documents and the regular posts accept this extension however, "download system" did not accept it today? Can you please suggest on this?
